Which tables? - FirebirdV6.com/CamaroV6.com Message Board
Which tables?
  • Which tables?
    quick question..when pulling a certain amount of timing from cells in HP Tuners..do you just pull it from the high octane table or from both the high and low octane tables?..thanks!
    i always sort out my high octane then copy & past that to the low octane, then pull 2-4* across the board in the low octane...If i have to adjust the high octane at some point I just repeat.
    00 GTP<br />98 Camaro v6<br />See, told ya I\'d be rockin another 4th gen :D<br />V6 & V8 tuning available at <a href=\"http://mysite.verizon.net/whenn1/\" target=\"_blank\">http://mysite.verizon.net/whenn1/</a>
      cool..thanks!
        I think most people set up their high oct. table first then copy and paste that to your low oct. table and -subtract 3 to 4 degrees from the low oct. table. I know thats how I've been doing it. Like on mine, I added 3 degrees across the board on my high oct. table and copied and pasted it to my low oct. table, then went and subracted 4 degrees from the whole low oct. table. After I did that I ran my car to see if I had any KR. If I did I would go back to the high table and take off the KR I was getting. If I made any changes to the high oct. table I would go ahead and copy it and paste it to the low oct. table and subract 4 degrees. So basicly the low oct. table should be 3 to 4 degrees(your choice) lower than your high oct. table. Hope this makes sense. Steve
          got it..this weekend i'll be running race fuel and eliminating KR on the 175 shot [img]smile.gif[/img]
            I had to wire in resistors to desentize my knock sensors.
              whys that?..does that somehow eliminate false readings?
                Yes, it is suppose to get rid of false knock. Thats if you know it is really false knock. I set up mine to reduce it 35%. I know mine was false because no matter what I changed, race fuel, timing etc. it always showed knock at 2-3 spots everytime. It has worked pretty good so far.
