quick question..when pulling a certain amount of timing from cells in HP Tuners..do you just pull it from the high octane table or from both the high and low octane tables?..thanks!
Which tables?
Which tables?
<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Tags: None
i always sort out my high octane then copy & past that to the low octane, then pull 2-4* across the board in the low octane...If i have to adjust the high octane at some point I just repeat.00 GTP<br />98 Camaro v6<br />See, told ya I\'d be rockin another 4th gen :D<br />V6 & V8 tuning available at <a href=\"http://mysite.verizon.net/whenn1/\" target=\"_blank\">http://mysite.verizon.net/whenn1/</a>
cool..thanks!<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">
I think most people set up their high oct. table first then copy and paste that to your low oct. table and -subtract 3 to 4 degrees from the low oct. table. I know thats how I've been doing it. Like on mine, I added 3 degrees across the board on my high oct. table and copied and pasted it to my low oct. table, then went and subracted 4 degrees from the whole low oct. table. After I did that I ran my car to see if I had any KR. If I did I would go back to the high table and take off the KR I was getting. If I made any changes to the high oct. table I would go ahead and copy it and paste it to the low oct. table and subract 4 degrees. So basicly the low oct. table should be 3 to 4 degrees(your choice) lower than your high oct. table. Hope this makes sense. Steve08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
got it..this weekend i'll be running race fuel and eliminating KR on the 175 shot [img]smile.gif[/img]<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">
I had to wire in resistors to desentize my knock sensors.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
whys that?..does that somehow eliminate false readings?<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">
Yes, it is suppose to get rid of false knock. Thats if you know it is really false knock. I set up mine to reduce it 35%. I know mine was false because no matter what I changed, race fuel, timing etc. it always showed knock at 2-3 spots everytime. It has worked pretty good so far.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
by ssms5411So my truck is finally getting some work done, after 17 years, Oil pressure sensor went out and it’s located under the lower intake manifold. Have to...3 weeks ago
