I'm crusing on the freeway 55-60mph 3rd gear, laptop data logging. Floor the throttle. Pull to about 85-90. There is no lag, so its at full boost for the whole run.
1st pull, car pulls extremly hard, 19-20* of timing, no knock.
let off the gas coast to 55 again.
2nd pull, car pulls nearly as hard, but now showing 2-3* of knock.
let off
3rd pull, now showing 5-6* of knock.
let off
4th pull, knock is up to 10-11* car now has WAY less power.
A/F is constant over all the runs. Intake Air temp is 75-90* after intercooler.
Time between runs is time required to coast down.
This is on ethanol, with an octane rating of 106. Specific heat is close to that of methanol.
I'm wondering if this is just heat soak, made worse due to the iron construction of the engine?
Any thoughts on whats going on, or what to do? Should I pull the timing back initialy, or should I let the knock sensors pull it?
let off
let off
