Speed density question - FirebirdV6.com/CamaroV6.com Message Board
  • Speed density question
    I might be miss lead through my searches for info.
    Does the PCM default to speed density mode if the MAF sensor is inactive. I am having problems with my MAF system right now that I cannot figure out yet and the car runs better and seems to be quicker with the MAF unplugged.
    My concern is I don't know if I am running lean or rich at idle, WOT, etc. Right now I have a crap A/F narrow band and it basically says I am always a little rich and right now I can not afford a wideband for awhile.
    Can anyone tell me if it will hurt the car if the MAF is unplugged and whether I am most likely running rich or lean. I am running 8-9 PSI of boost.
    Modifications:<br />headers, throtle bod spacer, flowmaster, high flow magnaflow carsound cat, powerdyne sc with 2.9\" pulley and by-pass valve, walboro 255 fuel pump, spec stage 2 clutch, and HP Tuners
    Can anyone tell me if it will hurt the car if the MAF is unplugged and whether I am most likely running rich or lean. I am running 8-9 PSI of boost. [/QB]
    yes you can, and nope we cant tell.
    00 GTP<br />98 Camaro v6<br />See, told ya I\'d be rockin another 4th gen :D<br />V6 & V8 tuning available at <a href=\"http://mysite.verizon.net/whenn1/\" target=\"_blank\">http://mysite.verizon.net/whenn1/</a>
