That was a KICK A$$ writeup. Vey informative.
Good find!!!!
New Toy Red 94 Formula LT1
RT: .0006 60': 1.894 1/8 mile: 8.351 @ 84.89 1/4 mile: 12.974 @ 107.81
crashed Red 96 Camaro 3.8l: 14.91 @ 92.38
The ex wife's Black 98 Firebird 3.8l: 15.23 @ 88.12
it is extremely informative. I needed a writeup like that badly to help get me on the right track.
Do you think the tranny stuff would be the same on fbodies? That was on a regal so I am not sure about the torque management tranny stuff he did. I is pretty similar if not the same for us fbody guys I would think
yeah I been digging around and saved that one as a favorite...
this might help you on torque management it for an ls1, I believe.
DISABLE ALL TORQUE MANAGEMENT
Your a hardcore racer now why do you need a computer to tell you how much power you can have.
1: Open your editor, go to Edit>Transmission>Torque Management.
2: Set Abuse Mode Enable False
3: Set Abuse Mode RPM, Abuse Mode TPS and Abuse Mode Speed to 0
4: click over on Abuse Mode Torque Reduction vs RPM. I am referring to An A4 camaro SS here so dunno about anyone else. Set all values in Normal to 0.
5: You should now have NO TORQUE MANAGEMENT.
Originally posted by 97rs4life: Well here is an amazing tuning guide for all us beginners out there. Tells you step by step how to give your car a great tune!
00 GTP<br />98 Camaro v6<br />See, told ya I\'d be rockin another 4th gen :D<br />V6 & V8 tuning available at <a href=\"http://mysite.verizon.net/whenn1/\" target=\"_blank\">http://mysite.verizon.net/whenn1/</a>
Originally posted by viper04af: </font><blockquote>quote:</font><hr />Originally posted by foff667: PE tuning info is incorrect be careful
great so how do make it right? </font>[/QUOTE]Yea what do you suggest for this then? No wideband here either for me. Need to tune the best possible without one for now
I emailed the writer to change it but no update as of yet...basically he says that putting in a positive # intot he time vs rpm adder will richen the mixture...the exact opposite is true.
I reset my fuel trims when I was tuning, do I have to turn learning off now or how does that work? Will it just learn the fuel trims and then take care of itself?
