hey guys the other day i was out on the highway and i decided to top it out. I was in 4th gear at about 5 grand and it just stopped going up. It got up to a little before 120. are there any chips or what not that can increase my top speed? and if so what one would u reccomend?
governor?
HPP3 can do it, but forget I even said that.
Go with either HP Tuners or DHP Powrtuner.Matt
1998 Mystic Teal Camaro M5
You may also consider a mail order tune from TSP. That's probably your best bet.Matt
http://www.texas-speed.com/
Do a quick search in here and in Advanced Tech and you'll get a bunch of hits about their tuning.Matt
what modifications do you have. 200plus for the TSP mail tune is expensive if all you want to do is remove the speed limiter.2003 Chrome Silver Nissan 350z 6 Speed<br /><br />2001 Bright Rally Red Camaro 3800 M5-----SOLD but missed
jet scu 2000...corrects speedo for gear change, shift points, and elimates top speed limiter
$120
i have the programable PCM jet chip stage 2. and it still limits my speed. *shrug* maybe i have to "reprogram it"? i dont know how it works haha its just plug and play.Dave:
00 Supercharged Camaro - RIP
97 Turbo Camaro - Sold
the jet scu 2000 is not the jet chip stage 2 you have. It is different, this is a little blue box that you use to adjust stuff.
Originally posted by 97rs4life:
the jet scu 2000 is not the jet chip stage 2 you have. It is different, this is a little blue box that you use to adjust stuff.Dave:
Want a cheater way... Not sure if it works but in theory it should.
Hook up a toggle switch the VSS... You will lose your speedo and odometer while its off though.
how many of you guys with 2000 want your speed limiter removed removed?
Hell i might consider buying a '00 pcm on the side and remove your speed limiters do gear changes, and maybe lower your fan temps for like $50 and shipping [img]graemlins/rofl.gif[/img]-Eric<br /><a href=\"http://www.cardomain.com/id/mustangeater82\" target=\"_blank\">2000 NBM V6 Camaro 5-speed</a> T-top <i>converted</i><br /><b>14.467@95.45mph</b> <i>$0 in mods</i><br /><i>The member formerly known as MustangEater8251</i>
