some explain to me - FirebirdV6.com/CamaroV6.com Message Board
some explain to me
  • some explain to me
    www.turbov6camaro.com/tuning
    thats my log
    i take it our MAP maxs at ~104 ???
    these are hiting ~6.4-6.8 PSI
    this was with my WB O2 also not sure if its read exacly right or not (if HPT it putting out the right AFR for the my gauge....)
    also is my IAT sensor bad ? there know way at 7
    psi its only 90-94* intake air temps
    also i notic some KR but NEVER when under boot it just kinda show up... so anyone think this is false?
    1997 3800 Series II Camaro
    is your iat located before or after the turbo? If its before the turbo then id say its probably fine...if its after the turbo do you have an intercooler? If its after the turbo with an intercooler it might be ok...if you dont have an intercooler its definitly off. Yes your map maxes at ~104. I think the few little blips of KR you do get is probably false. Were all gonna have to start logging cyl air pid once 2.0 is out...i only see the first column in the histograms again :(
    00 GTP<br />98 Camaro v6<br />See, told ya I\'d be rockin another 4th gen :D<br />V6 & V8 tuning available at <a href=\"http://mysite.verizon.net/whenn1/\" target=\"_blank\">http://mysite.verizon.net/whenn1/</a>
      there no way my IC drops it back down ambient temps.......... the IAT is just before the TB
      what you mean first colume of histograms? i see them all
        he is talking about the problem with our histograms.
        BTW any word when 2.0 comes out and any benefits we will see from it. I found out yesterday my preowned bought version of hptuners makes the cut for a free upgrade to 2.0 by 5 days. [img]graemlins/rock.gif[/img]
        EDIT realized you had your scans posted...
        not sure I wouldn't bee to worried it could just be false knock and you weren't at 100% WOT when it happend.
        [ August 24, 2005, 08:33 PM: Message edited by: shenanigans ]
          not sure when it will come out but they are working on getting some of the v6 scanner bugs worked out...the maf fix viper got with his version of 1.7 is included as well as the etc limiter little g had problems with for his 2 step is now a parameter. Also this is a ground up software build...everything is new, you name it they changed it, altered it, made it better or just plane put it in there. Scanner is better & more powerful...more things you can scan at one time...all 8, yes 8, histograms are fully customizable to your liking...you can change replay speed as well...the new compare feature is badass...theres just so much stuff it would take me hours to post all of it...once its ready you'll all get your chance at it.
