i was just wondering if there is ANY company that makes a power programmer for a 1999 V6 camaro? All i have found is for 2000-2002 v6's.The reason why i need it is because i just got a new rearend installed on my car from a WS-6 Trans Am.I've upgraded from 3.08 gears to 3.73's,polyurethane brushings,swaybar,complete suspension,ect. I'll list everything if you want me to,but i REALLY need a higher top speed,right now i bury the needle at 125 at 4,000rpm and it won't accelerate any more. :( see i just got back from basic training in the army and i finally have a lot of money to put into my car. But i really need a programmer.HELP PLEASE!!
99 V6 programmer
Been said 100 times....HP Tuners or DHP Powrtuner. Do a search for more info on each of those. [img]smile.gif[/img]
FWIW, with lower gears you'll hit the limiter slower than stock, which is 118 mph. ;)Matt
1998 Mystic Teal Camaro M5
Doesn't matter. The fact that you have lower gears causes you to be limited to a slower speed, because the PCM limits it by RPM not MPH. Getting the tuner will fix this, but the fact remains that you aren't going 125 now. ;)Matt
i don't doubt that car will go 125 lol heres my list of things so far:
Flowmaster exaust
Strait pipe in place of cat converter
rkSport 02 simulators
BBK 80mm throttle body
Cam upgrade
Iridium RX spark plugs
Taylor plug wires
Air temp simulator
Jet electronic power shifter
B&M Shift kit
Positive traction-from 2002 WS-6 Trans Am
Upgrade from 3.08's to 3.73 gears
polyurethane brushings-Trans Am
35mm front Sway bar &25mmrear sway bar-Trans Am
Complete Suspension from the Trans Am
So i have done a little lol.i can't tell ya'll EVERYTHING i've done so far,that is just TOO much info about my baby!lol thanks for the help!!
