Is it necessary to have a BCM to get a 3.8 to run?
Originally posted by Jerriko: The BCM is required to get it to run. There is no way around it. The BCM has more parimeters that attach the PCM than just VATS.
All my 96 needed from the bcm to run was the vats enable signal which is now simulated from bypass I bought from painless.
Haven’t done anything on the Camaro, but put LEDs on my truck headlights . And my oil pressure sensor went out on the truck so going to fix that this...
