Wideband logging... - FirebirdV6.com/CamaroV6.com Message Board
Wideband logging...
  • Wideband logging...
    Do either of the two tuner companies offer some kind of wideband logging? I had heard rumors a while back, but haven't read enything lately.
    1997 Dodge Viper GTS
    hpt & dhp both offer input versions so you can just hook up your favorite w/b and log it within the scanner.
    00 GTP<br />98 Camaro v6<br />See, told ya I\'d be rockin another 4th gen :D<br />V6 & V8 tuning available at <a href=\"http://mysite.verizon.net/whenn1/\" target=\"_blank\">http://mysite.verizon.net/whenn1/</a>
      Thanks... I actually just found that out and came back to delete my post, but you already answered.
      Thanks though...
      What is the most common wideband box people are using?
        LC-1 I believe is the cheaper one... still like $200
        with hptuners you then need EIO which is $150
          I use an LM-1, which is more expensive than the LC-1. The LC-1, however, has been on backorder for quite a while. The LM-1 also has built in logging seperate from the tuner.
          Matt
          1998 Mystic Teal Camaro M5
            Lc-1s are on ebay [img]smile.gif[/img]
              So the LM-1 can log rpm and afr?
              Thats all I want.
                Thats all I want.
                I believe LC-1 will do the same and even through at least hptuners, so it will be listed right next to all your other readings at your mph.
                  Thats all I want.
                  do you want a tuning program or just to be able to monitor your a/f? Now your saying you want to log rpm & afr which you can get the lm-1 & and the rpm converter and log both of them...that'll run you ~$500. If you actually want to be able to tune that a/f all you'd need is hptuners or the like with the enhanced version that has inputs and an lc1 and nothing else since hptuners would already be scanning the rpms.
                    Yes I want the enhanced tuner and lc-1.
                    I wouldn't mind having HPTuners standard and the Lm-1 either, depending on the deal.
