nope that just deals with adjusting timing and fueling...
P/N limiter is usually somewhere simple but I am an idiot and cannot find it...
Engine-fuel control-fuel cutoff/dfco-rpm limits/cutoff *shrug* its a rev limiter so its under the same tab eric
00 GTP<br />98 Camaro v6<br />See, told ya I\'d be rockin another 4th gen :D<br />V6 & V8 tuning available at <a href=\"http://mysite.verizon.net/whenn1/\" target=\"_blank\">http://mysite.verizon.net/whenn1/</a>
Originally posted by L36Camaro: Oh well, I took a shot.
BTW, what does P/N stand for?
park/neutral
Originally posted by foff667: Engine-fuel control-fuel cutoff/dfco-rpm limits/cutoff *shrug* its a rev limiter so its under the same tab eric
Thanks... I am an idiot, I even went there but just overlooked it there. I was looking for a seperate spot for it. Wasn't it seperate in v1.7, I found it in 1.7 easily. I still haven't gotten a total feel for the new look.
Either way, thanks... not sure if I have decided or not to launch off the limiter.
