it'll help me out too..i switched from the 120 mph gauge face to a 150 mph one..now of course the speedometer reads too high..keeping the same cluster, what would i have to change using HP Tuners to correct this?..thanks!
little test for you
little test for you
<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Tags: None
scan a log and watch what the PCM reads as your speed and see if that is right......
the pulse's are the same from the trannys so it should not read different
the RPM should be a good bit off thoughwww.turbov6camaro.com
1997 3800 Series II Camaro
it reads different because although its the same scale as far as how far the needle can travel on the speedometer..but the numbers now go from 0 - 150 instead of from 0 - 120 ..now as i go faster the needle has to go slower than it used to..because now 80 mph is where 60 mph used to be..the rpms are actually fine because that face is the same as the old one..only mph is different..is pulses from the tranny what i would change?..or pulses from the speed sensor?..and what would i change it to?<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">
60/80 = .75 or 75% or 80/60= 1.3333333
so take your speedo number in HPTUNERS and mutply buy one of those and see if that fix's it.... it should the you can dial it in
NOTE: the gauge will be right but the number in the PCM will be WAY WAY OFF NOW. jacking up your A4 shift points badly
tune with care [img]graemlins/stickpoke.gif[/img]www.turbov6camaro.com
hmmm..i'll give it a try..almost better to leave it where it is i guess..i know how fast im going anyway because i know where the numbers were on the old gauge face<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">
yeah i got it to work..but you were right..it was either to 2 --> 3 shift or the 3 --> 4 shift..the shift point was so high it was off the tach and i hit the rev limiter!<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">
yeah i got it to work..but you were right..it was either to 2 --> 3 shift or the 3 --> 4 shift..the shift point was so high it was off the tach and i hit the rev limiter!www.turbov6camaro.com
This might work.
Set your PCM tune back to stock but put this btwn the PCM and speedometer and adjust:
http://www.dakotadigital.com/index.c...rod/prd126.htmWayne<br />94 5 spd Camaro<br />Turbo/Intercooled<br /> <a href=\"http://www.geocities.com/Mustang732/cars.htm\" target=\"_blank\">http://www.geocities.com/Mustang732/cars.htm</a> <br /><br />Megasquirt Stand-alone EFI controling fuel/spark w/ wideband:<br /> <a href=\"http://home.att.net/~basic-4/2ndMegasquirt/NewMegasquirt.html\" target=\"_blank\">http://home.att.net/~basic-4/2ndMegasquirt/NewMegasquirt.html</a>
