Please help, 1st hp scan - FirebirdV6.com/CamaroV6.com Message Board
  • #16
    i always do my WOT scans on the merging ramps of highways.. then again i only live about 2 miles from a highway so its not a very long drive for me
    <b><a href=\"http://www.cardomain.com/ride/2288859\" target=\"_blank\">1999 Mustang GT(Car Domain)</a><br /><a href=\"http://www.cardomain.com/ride/2123740\" target=\"_blank\">1998 Pontiac Firebird(Car Domain) *SOLD*</a></b> <br /><br /><a href=\"http://www.camarov6.com/cgi-bin/ultimatebb.cgi?ubb=get_topic;f=9;t=000902\" target=\"_blank\"><b>PA</b> - Maple Grove Test\'N\'Tune <i>April 15th</i></a>
    • #17
      Yah, traffic is heavy on I-95, not a good time to try. It's about 5 mi from the apt. Ok, I will post this on that site. Look for: 3rd r4n It looks like jibberish. It is posted. I saved it as a log file.....EDIT: I can read it on the VCM scanner but not that site. I will e-mail it to you now....SENT 3:57 PM
      Jessica :)<br />Kansas: There\'s no place like home...99 Firebird Blown/6lbs, Eaton w/3.42\'s CI headers Z28 Exaust<br />CAI, #36 injectors Intense PCM
      • #18
        haha..me too
        • #19
          sorry jessica.. didn't see you e-mail.. here is your scan
          http://amoxsoft.com/mike/new2/view.p...ber_view=mattg
          • #20
            jess e,ai;ed you back
            let me see you bin file please
            www.turbov6camaro.com
            1997 3800 Series II Camaro
            • #21
              Could you tell me where to find it? If it was something I had to save, I didn't. If the program automatically does it, I just need to find it.
              • #22
                AIM me to tune, your not on, v6turbocamaro &lt;&lt; my AIM
                • #23
                  the scan i got from viper doesnt look bad...conservative but it doesnt look bad...I dunno if id trust the fueling though...if you can get an a/f readout on a dyno that would be a good next move. cuz right now your commanding a base of 12.4:1 moving down slowly by rpm. I assume you still have the powerdyne fmu which will skew those #'s so thats why im saying to throw it on a dyno with a wideband so we can at least see some actual a/f #'s timing is very low in both the high/low octane tables but all that was done was gtp timing was copied & pasted by the tuner...which is eh...I dont know if i wouldve copied the whole table considering gtp's have a positive displacement blower whereas yours is a centrifugal and its rpm dependant as far as how much boost it will put out. Any specific questions you can hit me up on AIM as well.
                  00 GTP<br />98 Camaro v6<br />See, told ya I\'d be rockin another 4th gen :D<br />V6 & V8 tuning available at <a href=\"http://mysite.verizon.net/whenn1/\" target=\"_blank\">http://mysite.verizon.net/whenn1/</a>
                  • #24
                    I have 36# injectors no FMU. I always run premo.
                    It is running worse than stock...The PCM is from intense racing, so that explains the L67 table values.
                    • #25
                      yeah i pm'ed you back
                      you need an IC badly !!!! :eek:
                      i would get to WB
                      • #26
                        Jessica2112, I can give you a copy of mine, my air/fuel is right around 11.5 and my fuel trims are set up perfect. Also zero KR. Either send me your bin. file I can set up the file and send it back to you use or I can send you mine and you can copy and paste my tables into yours. I think it would be a good starting point for you to use since we both have powerdynes and 36lb injectors. My timing is also set for AZ weather , so you shouldn't have any KR. The only thing I differnet I see would be the Air/fuel in the higher areas of boost, you might run a little richer than 11.5. Running it rich until you get a wideband won't hurt though. Let me know.
                        • #27
                          Thanks, I would appriciate it. It would give me something to compare mine too. Send it to 38scv6@gmail.com (I don't mind posting the addy)
                          • #28
                            File sent.
                              My Hptuners stop working
                              Getting a massage saying invalid interface, haven’t used it since last year probably November. First time in 23 years I had a problem. Going to get...
                              14 hours ago
                            • Money pit
                              Zzp cams
                              by Money pit
                              Has anyone used zzp gt1 cam if so is it worth the money and time
                              2 days ago
                            • thatpewterfirebird
                              2001 3800 s2 firebird
                              by thatpewterfirebird
                              4 days ago
                            • Turbo 3800 camaro
                              Where are the videos?
                              by Turbo 3800 camaro
                              6 days ago
                              New Chevele
                              Just saw it on Facebook, looks awesome. The front and rear nice looking....
