Worried... Just increased spark timing - FirebirdV6.com/CamaroV6.com Message Board
  • Worried... Just increased spark timing
    My car feels like its to fast. I can't floor it in first gear at all or my tires spin or hop and if i accelerate through a turn in 2nd gear now my car goes sideways..
    I only took it on 1 WOT run because it seemed to fast, and I want to make sure I am not damaging anything before I continue.
    This is what I did.. read my PCM added 2 to the high octane table, copied the high octance table into the low octane table(after I added to previouslly) Then wrote it to my PCM
    Was that right or did I do something wrong?
    I am on my girlfriends PC so I can't post my scan.. she has win 98 and my jumpdrive doesn't register on her computer so I will post the scan tomorrow. There is KR at the top of first gear and at the top of 3rd gear, the most KR in first gear was 1.1.
    [ December 06, 2005, 10:52 PM: Message edited by: Matt G ]
    <b><a href=\"http://www.cardomain.com/ride/2288859\" target=\"_blank\">1999 Mustang GT(Car Domain)</a><br /><a href=\"http://www.cardomain.com/ride/2123740\" target=\"_blank\">1998 Pontiac Firebird(Car Domain) *SOLD*</a></b> <br /><br /><a href=\"http://www.camarov6.com/cgi-bin/ultimatebb.cgi?ubb=get_topic;f=9;t=000902\" target=\"_blank\"><b>PA</b> - Maple Grove Test\'N\'Tune <i>April 15th</i></a>
    1.1 is nothing at all, probably false knock. Did you copy the original high octane into the low octane table, or the high octane plus 2 into the low octane?
    http://www.bowtiev6.com/
      high octane plus 2 can I increase the spark timing more?
        yeah probably... I am playing with adding timing,a nd I see knock in the top end of each gear too...
        Ideally you want 0 knock.
          and to remove knock i would decrease timing I suppsose? How do i know which cylinder mass to decrease the timing in or should I do it for the entire row that the rpm is at?
          what are some other thing I can do in hp tuners to add some horsepower?
          increasing the timing has given me a VERY noticable increase of horsepower.. i was amazed when I floored it.. doesn't feel like the same car
            I added another 2 to the spark timing, and changed the injector from 2.17 to 2.45, I scanned it and The highest KR I saw was 1.7, that was only at one point in the run though, other then that I saw KR in one other place and the highest it went was 0.9
            How do I get rid of the KR that was 1.7?
            It seems to keep happening at the top of 1st and the top of 3rd (in the 3600-4800 range)
              Does increasing spark timing really help that much?? And if it does, it'll probably make a big difference in gas right???
              -MoE
                it gave me a large boost in torque.. I can feel it when I press the accelerator, there was a very large difference going from the stock tune to adding 2 to the table and copying it to the low octane table
                not to mention how I can't floor my car in 1st gear with out the tires spinning or hopping and in 2nd gear I could always accelerate through turns, now if I try to do that my rear tires spin in 2nd
                  low octane table should be -4 from the high octane table
                  what is the hit count on the KR your seeing?
                  www.turbov6camaro.com
                  1997 3800 Series II Camaro
                    The highest i have seen is a 2.1, and thats after I increased the timing by 7
                    Some one just told me I wasn't suppsoed to increase the whole table when increasing the timing.. what am I suppsoed to increase? I will change the timing of the low octane table.
                    [ December 05, 2005, 09:18 PM: Message edited by: Matt G ]
                      send me your bin file if you can
                        I have to wait until tomorrow to send files.. I have been logging my runs and taking the KR histogram and subtracting that from the high octane table.. is there a way to do the histogram all at once instead of doing the cells indvidually?
                        How do I create a .bin file? I know how to make a .cfg but i've never made a .bin
                          well its .hpl i think if you have 2.0
                          the bin file is the file you tune/open to make changes... email that and your scans to me
                          (I can tune 1998 ;) )
                            okay I will send them to you.. but I was hoping to try to learn how to tune my car. Will you tell me what you did so I can compare the two files (stock and the modified) that way I can try to learn
                              You need to watch the KR and timing histogram. These will tell you exactly which fields are being used on a WOT run. It will be mostly the last two columns towards the bottom. I would just start with increasing the timing in those cells. The cells that have KR, decrease the timing in that cell by the amount of KR.
                              92 S10 3800 A4(96)<br />1/4: 14.374 @ 92.25 w/ 1.976 60\'<br />Turbo and 12\'s Coming Soon!
                                6 days ago
