97 speed limiter removal - FirebirdV6.com/CamaroV6.com Message Board
  • 97 speed limiter removal
    Well I flashed a spare A4 PCM I had with a M5 bin and it worked just fine but I also changed the limiter from 118 to 150 under the speed limiter tab. Is there something else I am suppose to change to up the limiter to 150 or should that work? The guy I sold to PCM to says he is still hitting the limiter at 118.
    I emailed HP but haven't heard nothing yet, so if you have any ideas why it isn't changed, PLMK.
    http://www.bowtiev6.com/
    Did you have to have the dealer flash it with a 97' m5 vin# or did the Hptuners work as in changing the vin# and settings? I think when I did mine there were a couple of sections where you have to change the limiter. I'll look at mine and see.
      I looked at mine and this is what I changed,
      Spark Advance/ speed limiter vs. gear
      Torque Mgmt/ Abuse & Diff. score abuse
      Speedometer/ speed limiter disable 1 inj. and 2 inj.
      Speedometer/ speed limiter vs. gear
      I think that is all , thats the ones I changed and I know mine is gone. On the dyno in 4th gear I hit 137 mph. Good luck
        I did a full rewrite myself with hp tuners. I looked at the Spark Advance/Spark Limiter vs. Gear and this is what it is set at:
        1-60
        2-60
        3-95
        4-115
        5-116
        So I have to change those numbers as well? I thought the speedometer/speed limiter vs. gear and speedmeter/speedlimiter disable 1 inj and 2 inj. were the only ones that needed to be changed.
        So what numbers should I put in then for each gear in the Spark Advance/Spark Limiter vs. Gear screen for the limiter to be 150? Just the 5th gear one or change them all?
          I think I changed just the 4th and 5th gear. I think I put mine at 155.
            you guys going make my type a write up for this to ?
            Sparklimter speed Vs gear i change them all to 250
            and
            speedometer -> speedlimiter
            both injectors to 250
            Speed limiter button
            set all gears to 250 and resume at 245
            www.turbov6camaro.com/images/speedo.JPG
            1997 3800 Series II Camaro
              Why not, you have every write up over there any how. Lol
                5 days ago
