I only got the standard and the not the enhanced with the wideband hook up. Is there any tuning I can do now before I get a wideband gauge and the wideband hook up to HP Tuners?
Got HP tuners for Christmas
speedo recal
remove torque management
some timing adjustment
cooling fans+ thermostat
!cat, delete of code
maybe see what other SC guys are doing as well...
and start scanning to see what your problems are-Eric<br /><a href=\"http://www.cardomain.com/id/mustangeater82\" target=\"_blank\">2000 NBM V6 Camaro 5-speed</a> T-top <i>converted</i><br /><b>14.467@95.45mph</b> <i>$0 in mods</i><br /><i>The member formerly known as MustangEater8251</i>
read the sticky
help tune for your BOOOSTwww.turbov6camaro.com
1997 3800 Series II Camaro
Ditch your Fmu and put some 36lb injectors in and get rid of your TRC-1 if you haven't already. Then work on your fuel and timing tables. Also your fuel trims.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
not sure if this helps but sort of what I am driving around on, nothing fancy, just some of the basic stuff...(I keep a word document of everything I change, and several versions saved so I can go back to it.)
MustangEater Tune v1.35
December 5, 2005
Action 1
ENGINE>SPARKCONTROL>HIGH OCTANE
Add 5* of time across the board, copy high octane table to low, then subtract 4*
Action 2
ENGINE>FUEL CONTROL> COT, LEAN CRUISE
Remove COT protection. Set it to 275*
Action 3
October 23rd, 2005
Action 1
Recalibrate for new 3.42s in the rear
Tire height 25.7/3.42 = 7.51461988304094
October 10, 2005
Action 1
Remove Engine Torque management
EDIT>ENGINE>TORQUE MANAGEMET>RETARD VS. %TORQUE REDUCTION
Change all values to 0
Stock values
0 11 16 19 21 23 26 28 31 32 33 35 36 38 39 41 42 43 44 46 50
New values
All 0
September 6th, 2005
Action 1
*UPDATED*
Fan updates, updated for 160*stat
Fan 1 on/off at: 184°F/175°F
Fan 2 on/off at: 194°F/185°F
August 23rd, 2005
Action 1
Smoothed out some of the choppiness in the High and Low Octane tables
High Octane table
Changed Table values for 3,600 RPM @ 0.12 from 38 to 40
Changed Table values for 3,600 RPM @ 0.16 from 35 to 38
Changed Table values for 4,000 RPM @ 0.12 from 15 to 40
Changed Table values for 4,000 RPM @ 0.16 from 30 to 38
Low Octane table
Action 2
Raised Spark Limiter from 5975 to 6050
EDIT>ENGINE.SPARK ADVANCE> High RPM spark threshold
Raised Fuel cutoff
EDIT>FUEL CONTROL>Cutoff vs. RPM
Factory Settings
P/N 4900 4900
Reverse 6000 6000
In gear 6000 6000
My settings
6100 6100
6000 6000
6100 6100
EDIT>ENGINE.SPARK ADVANCE> ETC cutoff rpm vs gear
Factory
In gear 5900
Reverse 5900
My settings
In gear 6100
Reverse 5900
August 12, 2005
Action 1
Reset cooling fan temps for my stock 195* thermostat. Per hypertech’s site.
Fan 1 on/off at: 209°F/200°F
Fan 2 on/off at: 219°F/210°F
Action 2
Adjusted speedometer for 275/40/17 wheels.
Tire height = 25.7
25.7/3.23 = 7.95665634674923
Action 3
Reset speed limiter
New speed limiter is 150 mph
Action 4
Set first gear spark limiter to 45 mph.
Stock 35 mph, new 45 mph.-Eric<br /><a href=\"http://www.cardomain.com/id/mustangeater82\" target=\"_blank\">2000 NBM V6 Camaro 5-speed</a> T-top <i>converted</i><br /><b>14.467@95.45mph</b> <i>$0 in mods</i><br /><i>The member formerly known as MustangEater8251</i>
[QUOTE]Originally posted by shenanigans:
Action 1
Thanks Eric, can you explain why?
[QUOTE]
[QUOTE]
Action 2
Remove COT protection. Set it to 275*[QUOTE]
What does this do?Modifications:<br />headers, throtle bod spacer, flowmaster, high flow magnaflow carsound cat, powerdyne sc with 2.9\" pulley and by-pass valve, walboro 255 fuel pump, spec stage 2 clutch, and HP Tuners
first part adds timing to the car. Second part removes the cat. conv. temp protection when running no cat. conv.
Yep the first part is adding some timeing, I woudl not do it I believe FI cars retard it. Not sure on what tuning is needed with that.
As for the second one.. The computer adds fuel to the car to help protect the CAT, I set the temp higher so it doesn't do it.
I don't really do it for daily driving, I have it enabled at the moment but thinking about ditching it for good and if my cat goes bad earlier I might jsut !CAT it.-Eric<br /><a href=\"http://www.cardomain.com/id/mustangeater82\" target=\"_blank\">2000 NBM V6 Camaro 5-speed</a> T-top <i>converted</i><br /><b>14.467@95.45mph</b> <i>$0 in mods</i><br /><i>The member formerly known as MustangEater8251</i>
need help finding a balancer and a replacement balancer bolt. im at a lost after confusing myself researching.2 weeks ago
Hello every one, ozzy here ive been looking at this page for weeks now finally joined. So my question is why is it that every turbo build forum just ends...3 weeks ago
