i got the dhp hooked up to my car and got codes out. that was realtivly easy. now i want to scan my pcm while i drive/have the car running. i thought i had the logs saced and was able to open them. but when i open them all i see is zeros for the values and dont know where to go to see it in real time. i have looked everywhere and cant seem to find all this info. if you can help it would be appreicated
thanks
Have you checked the DHP forum? There is tons of info there. That's without a doubt the best place to ask this question.
What version are you using?
To view real time stuff you gotta check the box in the scan tool for the ones you want to view. That'll pop up the window and show the live data.
To record it, you have to press a button to start recording. Then when you disconnect it'll save all the data to the database in the program. Finally, you go to Scantool | Logs | Export Log. Select the right one and save it to a file.
i looked all over the dhp forum. couldnt find a thing and i looked for at least an hour. whenever i cnose the one i wanted to view realtime and then recorded them i didnt see anywhere to see it real time. the version i use is 1.1.9e. it seems to work fine. i been looki for a walk through type thing and cant seem to find it.
the only one i found was to tune the pcm but not how to open and get to all that.
