Yeh so i installed my jet performance chip the first time but when it got done being installed and i fired up my car my gas gauge wasnt working it was either empty or all the way full. So i took it back off and then reinstalled it . same thing ... finally the third time i did it no gas gauge malfuncion.. but the only problem is i noticed that my fans were running when i had it in the first two times and it was an improvment over stock .. the thrid time.. cant really notice a diffrence.. do these chips really work??
Jet Performance Chips??
I had one for a long time until I got HP Tuners. I never had those problems that you did. I noticed an increase in low end torque. Did you make sure you unplugged the battery before you installed it? I think th e instructions said to do that but I am not completly sure.Modifications:<br />headers, throtle bod spacer, flowmaster, high flow magnaflow carsound cat, powerdyne sc with 2.9\" pulley and by-pass valve, walboro 255 fuel pump, spec stage 2 clutch, and HP Tuners
