Well I was just recently informed that HP tuners now has free updates for life so I was able to dl the 2.1 version finally. Quite a jump from 1.7, lol. Originally my update period was over when 2.0 came out.
Time to learn the ins/outs of this new version.
So if you still only have 1.7, get onto hp tuners and get the update!
Improved - License Info and VCM Suite Info for MPVI interfaces.
VCM Scanner
Added - Complex function support for custom PIDs and filters.
Version 2.1.0
General
USB MPVI - Initial public release.
VCM Editor
Added - More LS2 and LS7 parameters.
VCM Scanner
Added - LS2 and LS7 VCM Controls.
Version 2.0.18
General
Installer - Improved Microsoft .NET 2.0 detection.
USB Driver - Updated from version 1.1.1 to 3.1.4.
Improved - VCM Suite calculator functionality.
Improved - Vehicle detection and handling system.
Added - License information forms added to the help menu in both VCM Editor and VCM Scanner.
VCM Editor
Added - LS7 support.
Added - 4.3 V6 truck support.
Added - More supported LS2 vehicles.
Added - More LS2 Parameters.
Added - MAF Freq Fail for most GM V6 vehicles.
Added - Relink VATS to the Flash menu.
Added - Support for new GM LS1 OS's for 2004 and 2005 vehicles.
Added - A few LS1 fuel level and open loop parameters.
Bug Fix - Speedo Scaling tire size "Error" for some GM V8 Trucks.
Bug Fix - Cranking VE table fixed for GM V8 OS 12221588.
Bug Fix - Incorrect VATS for GM V8 OS 12592433, 12591347, 12587604.
Bug Fix - DFCO bug in GM V8 OS 12592425.
Ford - Added more parameters and improved layout for the navigator.
Ford - Fixed an issue with setting some switches.
4 Cyl - More parameters added.
VCM Scanner
Added - More LS2 parameters.
Added - Cylinder Balance and CASE Learn to VCM Controls.
Functionality - Increased histogram axis string length.
Bug Fix - Logging multiple identical sensors with EIO would return the same number for all.
Bug Fix - Fixed torque PID for some GM V6 vehicles.
Bug Fix - Rare issue with the Chart marker line not being displayed after scrolling.
Bug Fix - Rare histogram issue when logging a manufacturer and user defined PID of the same sensor type.
Version 2.0.17
General
Installer - Added the ability to customize your installation location.
Core - Improved internal support for Ford based vehicles.
Core - Improved progress bar performance.
Help Files - Screenshots improved.
Help Files - More information added.
VCM Editor
Bug Fix - If you wrote a PCM and then read it immediately after the Save dialog would not show.
Bug Fix - Undoing a table display no longer resets the view or changes the 2D graph colors/symbols.
Bug Fix - A rare issue when DTC list is displayed and you open up another file, VCM Editor would crash.
Bug Fix - Fixed an rare issue with Serial EIO's that could not locate VCM's on a write.
Bug Fix - After a PCM Write, validation status now shows Completed.
Bug Fix - Fixed a very rare LS2 entire write issue.
Bug Fix - Fixed a small issue with colors in compare mode when compare is not possible on a parameter and the main file parameter has changed.
Ford - Added parameters and completed layout to the navigator.
VCM Scanner
Added - Reset Peaks to Gauge Display right click menu.
Added - Last known vehicle history clear option in Options window.
Added - Clear All Data to Histogram Display right click menu.
Improved - Gauge Display needles.
Bug Fix - Custom PIDs and Filters are no longer case sensitive.
Bug Fix - VCM Controls now work for more than 5 seconds when not actively scanning.
Bug Fix - Fixed an issue where user defined AUX's defined as Sensors would not be used for user defined PID functions.
Bug Fix - Fixed an issue with user defined AUX's defined as a list value sensor type displaying properly in Histogram and Chart.
Version 2.0.16
Public Release - This is the first VCM Suite 2.x public release.
Version 2.0.15
Beta Release - Switched installer programs. The new installer has better .NET Framework detection and error messages.
Functional Links - Now when you double click items in the Change Log, History Log and Compare Logs the parent forms will open.
Incomplete 1.x Features - The following features are not complete and/or do not function in 2.x software yet. VCM Scanner: VCM Controls Special Functions, EIO Outputs. VCM Editor: Force BCM/VATS Relink
Version 2.0.14
Beta Release - Mostly just improved help files.
Version 2.0.0
This is our second generation of software and our first major software upgrade. VCM Suite 2.0 is a complete rewrite taking over a years worth of feedback and experience from our 1.x line of software.
VCM Suite 2.0 uses a more graphical user interface than our previous version. It is also designed to be as functional as possible for the most advanced tuners while still remaining easy to use and user friendly for those just starting out. We believe that the new software build can cater to almost any tuner skill level.
VCM Editor
The new VCM Editor is now a combined edit utility as well as flash utility. Using the same piece of software you will be able to read the vehicle, make changes, and then write your changes back without ever having to open up any other applications. There are also many feature improvements including a full graphical color representation of parameters and very functional file compare.
VCM Scanner
The software now has a much more configurable interface. The interface and displays are fully configurable. One major feature of the VCM Scanner software is the ability to change your config file on the fly! While you're scanning you can load up various config files to adjust your chart, histogram and gauge layouts without even having to stop logging the vehicle.
Right Click Functionality
We have added even more right click functionality into our software. All parameters in VCM Editor can now be right clicked for quick modification and configuration. Items in VCM Scanner can also be right clicked for quick access to configuration screens.
Multi-Manufacturer Support
The software engine has been designed to allow the addition of other vehicle manufacturers. In the future we will be releasing more tuning products for other manufacturers using the same VCM Suite interface you have become so used to.
New User Interface
VCM Suite has received a major facelift in this version. The look and feel of the software is much more modern and full of color.
00 GTP<br />98 Camaro v6<br />See, told ya I\'d be rockin another 4th gen :D<br />V6 & V8 tuning available at <a href=\"http://mysite.verizon.net/whenn1/\" target=\"_blank\">http://mysite.verizon.net/whenn1/</a>
