accualy wait it should bottom out it 17:1 if it in free air, if it has been less then 6 hours since you turn off the car there is still some exhuast in the pipe and its reading that
Wideband install
www.turbov6camaro.com
1997 3800 Series II Camaro
Thanks guys, I got it all wired up but the long wire for the sensor is just rolled up in the engine bay for now. I need to borrow a jack so I can install the sensor.
I noticed the y-pipe that came with my headers already as an O2 bung right before the CAT so I am just going to put it in there as long as the plug is not rusted in there to bad.Modifications:<br />headers, throtle bod spacer, flowmaster, high flow magnaflow carsound cat, powerdyne sc with 2.9\" pulley and by-pass valve, walboro 255 fuel pump, spec stage 2 clutch, and HP Tuners
I noticed the y-pipe that came with my headers already as an O2 bung right before the CAT so I am just going to put it in there as long as the plug is not rusted in there to bad.www.turbov6camaro.com
Well got it all hooked up and my idle is going so lean it is maxing out the gauge.
that can also be caused from exhuast leakswww.turbov6camaro.com
Yea, I jumped the gun, as soon as the car warmed up it came down but is it normal for it to hover around 14.7 like .4 in each direction during idle and cruise.
Also will it read 14.7 as stoich evenif you change your comanded AFR. I Changed my commanded AFR to 13.5 just to be safe until I found out what the AFR actually is doing and it is still hovering around 14.7 eventhough my commanded is 13.5.Modifications:<br />headers, throtle bod spacer, flowmaster, high flow magnaflow carsound cat, powerdyne sc with 2.9\" pulley and by-pass valve, walboro 255 fuel pump, spec stage 2 clutch, and HP Tuners
If done correctly, and if handled correctly by HP Tuners, you should see the correct AFR that you commanded.Matt
1998 Mystic Teal Camaro M5
Also will it read 14.7 as stoich evenif you change your comanded AFR. I Changed my commanded AFR to 13.5 just to be safe until I found out what the AFR actually is doing and it is still hovering around 14.7 eventhough my commanded is 13.5.www.turbov6camaro.com
so what if you were running an open y-pipe and the WB was 5" from the opening of the y-pipe? would you see false lean then?2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
Originally posted by slow6:
so what if you were running an open y-pipe and the WB was 5" from the opening of the y-pipe? would you see false lean then?www.turbov6camaro.com
Hey guys. For starters I’ve always been a big car guy, I love all types of cars and can appreciate all types of engineering. I’ve always been a Chevy...4 hours ago
by ssms5411Getting a massage saying invalid interface, haven’t used it since last year probably November. First time in 23 years I had a problem. Going to get...2 days ago
need help finding a balancer and a replacement balancer bolt. im at a lost after confusing myself researching.5 days ago
