p0230 fuel pump code - FirebirdV6.com/CamaroV6.com Message Board
  • p0230 fuel pump code
    I got the p0230 it said something about fuel.
    Can you help me? thnx
    Re: p0230 fuel pump code
    P0230 Fuel Pump Relay Control Circuit
    Most likely cause is fuel pump relay. Other than that, could be a wiring problem.
    Matt
    1998 Mystic Teal Camaro M5
      can you tell me where the relay is?
      I'm hoping its just a simple wiring fix..
        It's in with all the other fuses and relays. Check your owner's manual to see exactly which one.
        Matt
          i've been pulling the 2 "Fuel" fuses,
          so that I can turn it over without it running (compression check, or to try to get my oil moving around).
          but I always put them back!
