just got HP tuners...few q's - FirebirdV6.com/CamaroV6.com Message Board
  • just got HP tuners...few q's
    ok i just got HP tuners today and i fixed my speedometer for the gearing/wheel change and changed a few little odd's and ends. But what i really wanna do is change my shift points and some other things...what can i do with it to give me a better tune over stock and maybe a little extra hp???
    Juiced Rally Red 98 A4<br /><br />Way too much to list....<br /><br /> <a href=\"http://www.cardomain.com/ride/2263415\" target=\"_blank\">http://www.cardomain.com/ride/2263415</a>
    Re: just got HP tuners...few q's
    To learn how to gain some extra hp by increasing timing read viper's write-up in the sticky
    Old Car = 12.679 @ 106.5 on 150 dry shot.
    New Car = 2010 3.6l 304hp Camaro
      good call! :thumbsu:
        hey man..i cant find that file i mentioned..but yeah viper's write up is really good..definitely the best place to start
        ____________________
        12 SECOND NITROUS POWERED 98 A4 V6 CAMARO
        www.MySickCamaro.50megs.com
        SOON TO BE FEATURED IN CAMARO WORLD MAGAZINE!
          yeah i did read his write up and i smoothened out the main spark vs airflow vs RPM open throttle, High octane...
            i dont think you need to smooth out the timing table
            only reason to subtract timing in a cell is if youre getting KR
            your next best step would be to get a wideband and the EIO ;)
            1dangv6: what file did you mention?
              add timing till the pistons bleed then take a little off the top :D: :wavey:
              okay not really :banana:
              www.turbov6camaro.com
              1997 3800 Series II Camaro
                ok i did some more tuning today....i will explain and let me know if im down the right path...
                i smoothened out the Main spark Vs. RPM vs Open throttle high and low octanes. Then i took it out for a spin logged on and at like 5200 RPMS it said -4 retard which was the highest retard from 0 RPM's to 5700. From vipers website help it says anything under 5 i believe is fine. So im gonna leave it at that. I messed around with some other things and made sure i didnt have any lean sports or anything. Am i doing the right thing or not??
                  take away 2* and see if the KR comes back
                  hard to tune fule with out a WB o2
                    i had a NA file around somewhere ..it had all the basics..lowered fan activation temps, timing curve modified and raised, higher shift points, etc..but i cant find it anywhere
                    yeah i enriched my AFR a bit for running nitrous..but like viper said..you REALLY want a WBO2 for that
                    __________________
