are the resistor chips worth anything? do they even do anything? i'm sure i could pick one up at radioshack for like under a dollar, and if it's worth that amount, i could try it out. i have the 96 3.8 with cold air intake. i've also heard from someone i should get a new thermometer..is this neccessary??
resistor chips?
Re: resistor chips?
Originally posted by TheGr8Schlotzkyare the resistor chips worth anything? do they even do anything? i'm sure i could pick one up at radioshack for like under a dollar, and if it's worth that amount, i could try it out. i have the 96 3.8 with cold air intake. i've also heard from someone i should get a new thermometer..is this neccessary??
Re: resistor chips?
Haha, yeah i meant thermostat, didn't even notice that..Last edited by TheGr8Schlotzky; 06-29-2006, 07:41 PM.
Re: resistor chips?
http://forum.camarov6.com/showthread.php?t=65920
in short no. do a search and you'll come up with a bunch of reasons y not'99 Camaro Y87 M5 T-tops
Flowmaster american thunder cat back, 2.5" magnaflow high flow cat, centerforce dual friction clutch
Car Domain
