hey guys i drive a 95 V6,3.4L camaro.it all started like 2 weeks ago,i experienced some stalling at stop signs n red lights but when i pressed my gas padel a bit more it went ok,then one day i was driving on free way around 60mph and it started stallin all of a sudden,i had to press gas padel a bit hard and it was ok but now i continuously feel staliin specially at stops signs.
do any of u guys have idea wat might the problem be.
i really appreciate any help in this regard
thanx
Is this an automatic? Have you tried putting it in neutral when at a stop sign and seeing if it still stalls?
Does it just reduce rpm or does it die completly when coming to a stop?
Does it feel fine otherwise? No reduced performance during acceleration?
It could be the EGR valve sticking open. You might try disconnecting the connector on it and seeing if that changes anything. You'll probably get a SES light though while it's disconnected.
Has anyone used zzp gt1 cam if so is it worth the money and time
