When you put header on a car can you get a lean fuel fixture casue the exshaut is moving to fast past the 02 sensor so it gets low volts so it says lean fuel mixture.The code I got first was was P0151 Heated Oxygen Sensor (HO2S) circuit low voltage Bank 2 Sensor 1 I cleared it. That code did not come back and I got P0174 Fuel trim system lean Bank 2.
code tuning
Re: code tuning
sounds like more of a mechanical problem then anything...possible an intake leak.00 GTP<br />98 Camaro v6<br />See, told ya I\'d be rockin another 4th gen :D<br />V6 & V8 tuning available at <a href=\"http://mysite.verizon.net/whenn1/\" target=\"_blank\">http://mysite.verizon.net/whenn1/</a>
