has any one used this jet scu 2000? if any one has used it for the 98-02 firebirds what is your results on it as far as removing speedlimiter , and recalibration?
jet scu 2000?
Re: jet scu 2000?
Nachius used it on his comero. got it for the diff gears he put in. worked, but I don't know if it removed a speed limiter or not.... his was a 961978 Formula 461 in progress of being built :rock:
2013 Ram 1500 Big Horn
94 comero 3.4
Re: jet scu 2000?
I would rather get a mail order tune if I had a 97+ Cumaro2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
Re: jet scu 2000?
yea for a 97 and up f-body the tune is the way to go.
I ran an scu2000 for a while, it did remove the governor, your speedo just stops at 110. It recalibrated for gears but it took some time adjusting and playing with the settings. Also if you decide to go with one make sure you have a VERY GOOD GROUND.
Re: jet scu 2000?
Why not just get your car tuned, i just got my 2006 z71 done by this guy, very nice guy. For 250 you can not beat it. Give him a call and talk to him..... www.gowheatley.com Like i said, he did an awsome job on my truck, adjusted timing, removed speedlimitor, removed abuse torque management, increased idle, and other stuff, truck is running like a top. The reason i choose him to do it is becuase hes 10 miles from me. But he also does mail order. Im not sure if he does cars, but you can find out.<a href=\"http://www.cardomain.com/ride/2245261\" target=\"_blank\">http://www.cardomain.com/ride/2245261</a> Green 1997, 105k, all stock except for Z28 front springs, Air shocks in the rear, home made coolant recovery tank, home made battery hold down.
