96 3.8 Obd Ii ? - FirebirdV6.com/CamaroV6.com Message Board
96 3.8 Obd Ii ?
  • 96 3.8 Obd Ii ?
    I have a 96 firebird 3.8 v6
    do i have an OBD II ? how can i find out?
    SES light is on but running fine ,,whats the simplest way to get the codes ,?
    also is my pcm programmable ?
    thanks
    Re: 96 3.8 Obd Ii ?
    might have to get a 97 pcm
    go to autozone to get the codes scanned free
      Re: 96 3.8 Obd Ii ?
      You should have an OBD II. I was told that they started putting OBD II on all cars beginning with the 96 model year.
        Re: 96 3.8 Obd Ii ?
        thanks
        Yes.
        Go to AutoZone and have them scan it.
        NO, there is no programming available. It can be replaced with a 97 PCM, but ONLY a 97 PCM.
        Raven
          Re: 96 3.8 Obd Ii ?
          also the computer has to match the transmission you have
          unless you flash the computer to change the tranny with HP Tuners or DHP
            Re: 96 3.8 Obd Ii ?
            Wait one second there, the 97 pcm is compatible with a 96 camaro, given you need it to be programmed for your car, but its capable to put it in. y the hell are we one year short, whats the difference in our cars years if theyre the same?
              Re: 96 3.8 Obd Ii ?
              the code is different for the 96....97 pcms are a direct swap though as long as it is the same trans
              http://www.bowtiev6.com/
                Re: 96 3.8 Obd Ii ?
                the 96 pcm was a transition year for gm to obdII they basically converted a obdI to obdII standards
                also the 96 pcm does not have as much memory as a 97pcm
                the 96 pcm can be programmed with DHP
                3\" Eldebrock catback exhaust<br />rksport powerdyne<br />pacesetter headers<br />VS cam,compcams pushrods,ls1 valves,5 angle valve job,p&p,<br />and total seal piston rings<br /> <a href=\"http://www.cardomain.com/ride/804031\" target=\"_blank\">http://www.cardomain.com/ride/804031</a>
