I just put 36# injectors in my car and adjusted the injector table and now my car will not go into closed loop unless I do it directly from the VCM controls in the scanner. I am completely stumped on this.
One of the injectors is not working and throwing a SES of high circuit or something like that. Bank 2 fuel trim readings is a constant lean of 19.5%Could that cause this?
Modifications:<br />headers, throtle bod spacer, flowmaster, high flow magnaflow carsound cat, powerdyne sc with 2.9\" pulley and by-pass valve, walboro 255 fuel pump, spec stage 2 clutch, and HP Tuners
