hp tuners question - FirebirdV6.com/CamaroV6.com Message Board
hp tuners question
  • hp tuners question
    If I buy the program from hptuners do i need to buy a laptop to set it up to or can I just use my existing laptop ? thanks alot
    dan
    Re: hp tuners question
    The HP Tuners module uses a USB 2.0 Interface. Any laptop with Windows 98 or better can use HP Tuners.
    Chris<br />98 Firebird T-Top<br />3.8L<br />Whisper Lid W/ K&N<br />Pacesetter Headers, Ceramic<br />Catco 3\" in/out cat<br />TSP Rumbler Catback<br />TransGo Shift Kit<br />JET Corvette Servo<br />All KYB AGX Shocks/Struts<br />3.42 Gears, POSI Traction
      It doesnt have to be a usb 2.0 compliant laptop I dont think.
      Dont think mine is...
      You dont have to have a laptop at all if you get the MPVI EIO PRO which has stand alone data logging. But it would be preferable to have a laptop cause it would be alot easier than having to take your Desktop pc out there using an extension cord. lol
      You can use your existing laptop
      I'm not trying to send you away from here or anything... and you are Very welcome here!
      But HPT also has a forum where you can ask questions such as these and probably get a better answer
        any computer with a usb port will work with hptuners
        http://www.bowtiev6.com/
          thanks guys
            what are they talking about here this 8 credits crap you can only tune your car a couple times???? check it out
            http://www.hptuners.com/order.php
            thanks
            dan
              thanks
              dan
              you get 8 credits to use. To tune a single vin car it is 2 credits. Then you can tune that car as many times as you want but only that car. With 4 credits you can get year/model so if you got the 97 year/model 4 credit option you could do any 97 fbody 3.8l car.
              You can actually tune up to 4 seperate cars using the single vin option or buy a 97 year/model and do all 97 cars, then have 4 left over for other licenses.
                thanks alot, should I just go for the normal version or the professional whats the difference?
                  normal doesn't have the inputs for things like wideband gauge and also I believe the professional allows you to log data black box style where you don't need it hooked up to the laptop.
                  I personally just have the standard version and if I get a wideband I am going to rig it up through my egr wiring and trick hptuners into reading it. I have seen this done a couple times with success.
                  Up to you if you think you will use the black box logging and want the easier access to wideband hookups and such
                    the stand alone black box can record up to 1 hour and a 1/2.
                    I have it
                      did you notice a big difference when you got the hp tuners tuned??? you have a turbo kit like me right??? how much gains did u get
                        no turbo here
                          how much gains did you notice when you installed hptuners
                            depends on your tuning skills really. A poor tuner can loose power and a good tuner can gain a decent amount on a stock car.
                            You don't install hptuners like a hypertech programmer, you actually have to go in and make the changes to your stock pcm and rework tables and values
                              installing hptuners onto your computer will gain you 0 hp by itself
                              Like 97rs4life said, you have to change alot of things which is pretty technical, requires some good knowledge of how an engine works, etc..
                              It will take alot of gas at first and alot of time
                              and will take even alot longer to learn how to use it
                              but with other peoples help you will succeed if you are patient and persistant
