Can someone clarify this for me? - FirebirdV6.com/CamaroV6.com Message Board
  • Can someone clarify this for me?
    The Pin outs listing in the Firebird V6 Technical Database has the A/T Fluid Temp Sensor Input (A4) listed at Pin cavity's 68 and 71. According to the AllData pin out, it should be at Pin cavity 68, there's nothing listed at Pin cavity 71. Does anyone know why it is listed at two different cavity pins at the Tech Database? And which one is the correct one? Any help will be greatly appreciated. Thank you, Tommy.
    Re: Can someone clarify this for me?
    possibly a difference between years. What year car is yours? I would go with 68 as both alldata and the tech database list 68
    http://www.bowtiev6.com/
      You're reading the chart wrong.
      71 is for a 95-97 PCM
      68 is for a 98+ PCM
      Raven
        Awesome! I knew someone had the answer. I should have seen that! The year that I have is a 98. Thank you very much for your support, Tommy.
