Anyone who has a 98 Camaro with a 3.8 V-6 should have a PCM with this part number # Serv. No. 16236757. If you do have this PCM number, can you do me a favor by looking at your IAC valve wire connector and your EGR valve wire connector and tell me exactly what color wires are at each terminal letters. For instance your IAC wire connector has 4 letters on them. A, B, C and D. And your EGR valve wire connector has 5 letters on them, A, B, C, D and E. I need to know exactly what color wires are at each letter for each item. Your support will be greatly appreciated. Thank you, Tommy.
98 Camaro 3.8 PCM # 16236757
Re: 98 Camaro 3.8 PCM # 16236757
you don't need an exact 98 with that pcm and all. the wiring harness is the same for other years.
OK, I just found my Camaro CD parts catalog. According to this catalog the PCM and engine harness for 98 Camaro with the 3.8 engine and 4L60E transmission are both stand alones. Here are their part numbers:
PCM - 16236757
Engine harness - 12177562
It may be used by other models, but for the 98 Camaro with the 3.8 V-6 and 4L60E transmission, this is it. This could be useful info for some of you out there. Thank you, Tommy.Last edited by 3.8L Strong; 03-19-2007, 01:05 PM.
Originally posted by 3.8L StrongOK, I just found my Camaro CD parts catalog. According to this catalog the PCM and engine harness for 98 Camaro with the 3.8 engine and 4L60E transmission are both stand alones. Here are their part numbers:
PCM - 16236757
There is LOTS of info on THIS site if people would only look!
http://forum.camarov6.com/showthread.php?t=63721Robert - owner www.FirebirdV6.com/CamaroV6.com
Raven
FirebirdGT, yes, you are correct. Spending more time looking for that info would not hurt. I wanted to add in the engine harness number. I thought that this was useful info that others should be aware of. The PCM and engine harness with the part numbers mentioned in this thread may be stand alones for the 98 Camaro with the 3.8 V-6 and the 4L60E transmission, however, they are both used for other years and model GM vehicles as well. Thank you for your support, Tommy.
sorry, did you ever get the colors? Let me know and I will upload a wiring diagram for you
well I got the email returned, what is your new email?
hello....anyone there....need the correct email to send them to
My new email address is: Chevyone@hawaii.rr.com Sorry I took so long, I have been away for a while. Thank you, Tommy.
by Andy HHey everyone! I've been trying to remove my transmission for two days now! I need to replace the clutch. Only thing I've got left holding the transmission...4 weeks ago
