p0420 02 sensor replacement? - FirebirdV6.com/CamaroV6.com Message Board
  • p0420 02 sensor replacement?
    well my car threw a p0420 yestarday, thats a Catalyst System Efficiency Below Threshold (Bank 1), what are the causes? do you think it would be something wrong with the cat or with the sensor?
    K&N air filter, Whisper air lid, magnaflow LT1 cat back, and magnaflow high flow cat, pacesetter headers, silverstars<br /><br />more to come soon<br />but for now im out of money
    Re: p0420 02 sensor replacement?
    your cat has most likely taken a poop
    http://www.bowtiev6.com/
      I replaced the cat last year when I put my new exhuast on
        replaced it with what kind, and size?
          hey goober, what kind of car do you have.
          he replaced it with a magnaflow highflow cat. probably need an 02 sim or a new one if you have one
          2000 3.8 A4 Pewter Camaro
            I have a '99 camaro
            I replaced it with a 94100 series high flow from magnaflow, it says it will support up to 6.2L engines
            the cat has less than 10K miles on it but the car has 87K, O2 sensors usually start to go at around 80,000 right? so should I just replace the post cat one?
              with hiflow cats you should have went with an 02 sim and ditched that sensor anyways. Or have the code tuned out with hptuners
                I did seafoam about 2000 miles ago for the first time, I hear that can screw up your cat, is there anyway to tells if the cat is partially clogged or something
                  it can also screw up you plugs and 02sensors.
                  Do a back pressure test or engine vacuum test
                    Just have it tuned out or get an 02 sim. That's what happens when you get a high flow cat or delete your cat. It throws P0420.
