well my car threw a p0420 yestarday, thats a Catalyst System Efficiency Below Threshold (Bank 1), what are the causes? do you think it would be something wrong with the cat or with the sensor?
p0420 02 sensor replacement?
Re: p0420 02 sensor replacement?
I replaced the cat last year when I put my new exhuast onK&N air filter, Whisper air lid, magnaflow LT1 cat back, and magnaflow high flow cat, pacesetter headers, silverstars<br /><br />more to come soon<br />but for now im out of money
Originally posted by matt3989I replaced the cat last year when I put my new exhuast on
hey goober, what kind of car do you have.
he replaced it with a magnaflow highflow cat. probably need an 02 sim or a new one if you have one
I have a '99 camaro
I replaced it with a 94100 series high flow from magnaflow, it says it will support up to 6.2L engines
the cat has less than 10K miles on it but the car has 87K, O2 sensors usually start to go at around 80,000 right? so should I just replace the post cat one?K&N air filter, Whisper air lid, magnaflow LT1 cat back, and magnaflow high flow cat, pacesetter headers, silverstars<br /><br />more to come soon<br />but for now im out of money
with hiflow cats you should have went with an 02 sim and ditched that sensor anyways. Or have the code tuned out with hptuners
I did seafoam about 2000 miles ago for the first time, I hear that can screw up your cat, is there anyway to tells if the cat is partially clogged or somethingK&N air filter, Whisper air lid, magnaflow LT1 cat back, and magnaflow high flow cat, pacesetter headers, silverstars<br /><br />more to come soon<br />but for now im out of money
it can also screw up you plugs and 02sensors.
Do a back pressure test or engine vacuum test
Just have it tuned out or get an 02 sim. That's what happens when you get a high flow cat or delete your cat. It throws P0420.-Eric<br />2002 Navy Blue Camaro...Striped and Stalled. 35th Anniversary SS wheels <br />Best ET: 15.384 @ 88.32 on street tires<br />Project Whitney: Goal, 14.0 1/4 by summer 2008.
by ssms5411Not much going on, replaced my Kenwood double din stereo with a Pioneer double din, the Kenwood had problems. Then replaced my power inverter for my reverse...4 weeks ago
