I've read up the forum about how lower thermostats are only fully taken advantage of if you have a manual fan switch or reprogram your pcm to use the fans at that temperature.... my question is does the stage 2 jet chip program the fans to kick in sooner...if you use a lower thermostat (since a 180 degree thermostat is required for a jet chip anyways) would the chip make the thermostat more effective? thanx
Only time fans come on is if you turn on the A/C or the radiator is getting very little airflow (ie. sitting in traffic) so as long as you're moving and air is getting through the rad you'll be able to take advantage of the lower temp thermo.
Haven’t done anything on the Camaro, but put LEDs on my truck headlights . And my oil pressure sensor went out on the truck so going to fix that this...
