Someone explain to me why we need o2 Simulators - FirebirdV6.com/CamaroV6.com Message Board
  • Someone explain to me why we need o2 Simulators
    From what i've read through searching and reading in my time on this board, the post-cat sensor doesn't do anything to the engine, it only tells the computer if your cat is working correctly. To test an o2 sensor, you measure it's resistance at a given heat. If this is all a matter of resistance, than why do we have to spend $40 on a stupid plug that simulates a resistance to make the computer believe the cat is working? Why can't a simple resistor do the same job? The IAT sensor has been overcome with a simple resistor, so why doesn't a resistor work in this case?
    1996 Chevrolet Camaro
    1995 Buick Park Avenue Ultra
    --Appearance Moderator--
    Re: Someone explain to me why we need o2 Simulators
    shoot, this should probably be in intake/exhaust section, huh? Sorry about that. Someone can move it if they want..
      Anyone?
        don't see why it wouldn't work, probably all the o2 sims have in them I would imagine.
        But why not just get your car tuned and then remove that code?
        http://www.bowtiev6.com/
          Tuning will come, and when it does, i will surely remove that code. But first I have to buy a tunable PCM, and right now i'm saving for wheels, so that's out of the question. My cat is long gone and rattles like a mad man, my car sounds horrible. I want to straight pipe the cat but not throw a code. i would buy a hi-flow, but i don't see much point since we have no emissions.
          I think i'm going to go ahead and try that resistor thing, probably sometime this week. if i do, i'll let you guys know how it works out.
            Well, if you can figure out what the reading needs to be in order for the computer to read the sensor as working properly, then it should work. Just find which Oh You also would need to figure out the wiring for it. There's 4 wires for it all, so that shouldn't be too hard. If you have $40 to spare, buy a sim and tear it apart, and save the rest of us some money :P
            ~97 3.8L V6 Camaro~
            A few things
            Only Member of Team Hooker?!?
              or buy my extra 97 pcm with the code removed, speed limiter removed, fans changed if you have a low temp thermostat and if auto, I can remove the TM and firm the shifts up. $125 shipped to ya. :)
                Dangit. Now I want something new. I'm trying to save up for wheels, but that is an offer i find hard to refuse. I'll get back to you when I get my paycheck this friday.
