at 5400 there is spark knock out the ying yang and with only 14 degrees of timing, it's yanking 9 degrees out at this point on. the IAT temps are 185 at this rpm also.......hp tuners only goes to 176 degrees therefor anything after that, so no can fix. the maf is all but (might as well be) maxing out at 5400 to 5500 and beyond. i just read vipers site on the MAF, which is worth a shot.. but it still doesn't correct the 185 degree air.. also, about that KR "fix" on vipers site.... you may as well just shut the knock module off altogether which would fix the the KR problem and youd have no more KR problem right? wouldnt it beat the pistons off the wrist pins? i think turning it down a little may not hurt a thing..it may take very little to correct anyway...
any ideas? suggestions? this thing will never run right.
