Has anyone heard about someone that has modified to the extent of having to need one, on ANY GM 3800 II or III? My setup in the future will have one, more or less because I don't like HP tuners and I don't think DHP has enough to offer me for what I really want/need. Does anyone have any experience with an XFI system on any car?
F.a.s.t. Xfi
Re: F.a.s.t. Xfi
this is funny because i just picked up mine 3 hrs ago. i'll have a post on it all later on tonightBen<br /><br />1995 White/Black 3.4L<br />As far away from stock as possible<br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=288292\" target=\"_blank\">My Site!!!</a><br /><a href=\"http://www.redlinevsix.com\" target=\"_blank\">RedLineV6</a><br />Rebuild and 3.4 T70 Turbo is complete<br />Details to come....
Re: F.a.s.t. Xfi
Originally posted by White95this is funny because i just picked up mine 3 hrs ago. i'll have a post on it all later on tonight1995 Pontiac Firebird
Re: F.a.s.t. Xfi
ok heres as far as i've gotten this far. a complete system (xfi, tranny controller, and harnesses) cost around $3100. you need a tranny controller if your using an automatic. there is no direct harness for my 3.4 so i'm using a TPI based harness and making it fit.
thats about as far as i've gottenBen<br /><br />1995 White/Black 3.4L<br />As far away from stock as possible<br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=288292\" target=\"_blank\">My Site!!!</a><br /><a href=\"http://www.redlinevsix.com\" target=\"_blank\">RedLineV6</a><br />Rebuild and 3.4 T70 Turbo is complete<br />Details to come....
Re: F.a.s.t. Xfi
ok, update....i found out this weekend you also need a XIM computer to go along with the XFI ecu. the XIM controls the coils. so add about another $600 to the other $3100. other than that everything seems very easy to wire up. i'll have more details once i start the installBen<br /><br />1995 White/Black 3.4L<br />As far away from stock as possible<br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=288292\" target=\"_blank\">My Site!!!</a><br /><a href=\"http://www.redlinevsix.com\" target=\"_blank\">RedLineV6</a><br />Rebuild and 3.4 T70 Turbo is complete<br />Details to come....
Re: F.a.s.t. Xfi
nope i got pissed off at the whole stituation and currently trying to save up another $1500 that i need to get it all up and runningBen<br /><br />1995 White/Black 3.4L<br />As far away from stock as possible<br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=288292\" target=\"_blank\">My Site!!!</a><br /><a href=\"http://www.redlinevsix.com\" target=\"_blank\">RedLineV6</a><br />Rebuild and 3.4 T70 Turbo is complete<br />Details to come....
Re: F.a.s.t. Xfi
i had MS and its a PITA to use and couldn't mess with timingBen<br /><br />1995 White/Black 3.4L<br />As far away from stock as possible<br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=288292\" target=\"_blank\">My Site!!!</a><br /><a href=\"http://www.redlinevsix.com\" target=\"_blank\">RedLineV6</a><br />Rebuild and 3.4 T70 Turbo is complete<br />Details to come....
Re: F.a.s.t. Xfi
Originally posted by White95nope i got pissed off at the whole stituation and currently trying to save up another $1500 that i need to get it all up and running1995 Pontiac Firebird
Re: F.a.s.t. Xfi
no i haven't tried to install it cause just by looking at the harness i could tell it wouldn't work with my coils...i called fast and they told me i need a XIM computer as well which is about $600 once you add the harness and can module so its on hold for a little bit longerBen<br /><br />1995 White/Black 3.4L<br />As far away from stock as possible<br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=288292\" target=\"_blank\">My Site!!!</a><br /><a href=\"http://www.redlinevsix.com\" target=\"_blank\">RedLineV6</a><br />Rebuild and 3.4 T70 Turbo is complete<br />Details to come....
Re: F.a.s.t. Xfi
hey white, DIY auto tune is telling me that I can do timing and spark using the mega 2 V3 with little modofication. He said if i don't hook up the ignition control then i will run only 10 degrees of timing and that will cost me power obviously. How did your car run when you had it all wired up. u didn't have ignition control did you? i keep in mind i'm tuning na now and will onyl be running 6-10 lbs of boost.
Re: F.a.s.t. Xfi
yes you can run timing control with MS2...but NO ONE HAS DONE IT so you'd be completely on your own...i did not have the timing to mess with trying to hookup timing control nor did i want to try it and then blow my motor bc it wasn't set up right....i'm going to be running 20lbs of boost so i need something a little bit more trust worthyBen<br /><br />1995 White/Black 3.4L<br />As far away from stock as possible<br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=288292\" target=\"_blank\">My Site!!!</a><br /><a href=\"http://www.redlinevsix.com\" target=\"_blank\">RedLineV6</a><br />Rebuild and 3.4 T70 Turbo is complete<br />Details to come....
