how do i get the governer of the car? get it tunned? is it possible to get it taken off?
governer off?
Re: governer off?
only hptuners or DHP for 97s, there are jet scu2000's as well however they usually don't work.
Cheapest way is to get a mail order tune through texas-speed.com or pcmforless.com.
Where you located, maybe someone is local and can do it for ya as well
Re: governer off?
Because the speed limit where he is from is over 118 ;)
I say just disconnect the spedometer wire and then call it a day winding out 5th\'97 Camaro M5 Y87 3.23 LSD, homebrew CAI, highfloCat, Flowmaster catback, Pacesetter headers, specstage3 clutch and aluminum flywheel, !egr, 2kW system.<br /><br />Possible L67 bottom end w/ abbott heads and a turbo in the works... gotta do more homework
Re: governer off?
I know that there are parts of the T5 that don't like extra high speed, I forget what it is exactly but it has to do with the 5th gear and the output shaft I think anyway. If not that even, there is the definite weak link in the stock drivetrain - the 2-piece driveshaft. I wouldn't want that thing spinning too fast under me, god forbid that bearing decides to seize or something and the support in the middle gets ripped and that driveshaft flops back and fourth while driving 140 miles per hour... it'd be ugly i'd imagine. Aluminum driveshafts and gforce t5 ftw :cool:\'97 Camaro M5 Y87 3.23 LSD, homebrew CAI, highfloCat, Flowmaster catback, Pacesetter headers, specstage3 clutch and aluminum flywheel, !egr, 2kW system.<br /><br />Possible L67 bottom end w/ abbott heads and a turbo in the works... gotta do more homework
by ssms5411About a week ago noticed my brake lights not working also Hazards not working. Installed new brake switch and still not working, checked fuses and what...5 hours ago
