I got the Firebird fixed with the problems it had before, now I have developed a new problem. Im not sure if it is a dead short, or a PCM problem, but something is doing something else to make the car act like its starting over and over and over again.
When the car is RUNNING, there seems to be a short somewhere that activates the fuel pump primer, and at the same time, the SES light flashes in conjunction with the check gauges light. While this is happening the car wants to surge, probably because the PCM is ignoring the O2's and going thru a starting cycle, dumping more and more fuel in the engine. Whether or not I give it gas doesn't matter, it still wants to surge. Imagine the car running, but the key is in the ON position, and its getting switched to the START position probably 20 times a minute. I hear the fuel pump relay under my foot constantly clicking on and off, on and off, on and off, probably AT LEAST 20 times a minute. With the primer wanting to dump more fuel in there, disregarding the sensors because of it thinking its going thru a startup cycle, its surging badly.
My guess is a bad PCM. But maybe someone else has some other insight?
