hp tuners logs... - FirebirdV6.com/CamaroV6.com Message Board
hp tuners logs...
  • hp tuners logs...
    my friend has hptuners (i'm too poor right now...) and he offered to take some logs for me so i could figure out why my car has been acting so funky lately. He got three of them so i was wondering if anyone would be willing to take a look at them. i dont know how i can host it online (it has .hpl extension) so if you have hptuners, some time, and a kind heart could someone take a look at these?
    he said it's pulling something like 5* of timing advance and my o2's went dead for a second or two among other things, but he said he has no experiance w/ a 3800 (he drives an Ion Redline, which is modded to hell and would probably rape a stock Z). so he said he couldn't offer any advice on how to fix the problems.
    I think its pulling timing because the knock sensors may be hearing my lifter knock (i think its lifter knock at least... either that or a loud exhaust leak at the manifold) and taking it as precombustion... O2's may be a ground problem but i'm not sure. said also that fuel trim levels are lean.
    Shoot me an e-mail at hockeydom1234@comcast.net and i'll forward them on over...
    THANKS!
    Re: hp tuners logs...
    best way to tell how the a/f is, is to get a wideband on it. going by the narrowband O2s is a shot in the dark really. Not the ideal way of going about it.
    Was there any Knock retard in the scans?
    http://www.bowtiev6.com/
      tons of it he said. as soon as i punched it on the highway he gave me a "holy sh**" and said the kr was pulling 5* of ignition. if ya want i'll send 'em to ya...
        Send'em my way. lewisdr@email.uah.edu
        What does 'acting funky' mean?
        Do you have anything done to your car?
          bump!
          Dan seemed to be at a loss... anyone else?
            i get 3 codes:
            >> o2 sensor low voltage bank 1 sensor 1
            >> o2 sensor low voltage bank 1 sensor 2
            >> o2 sensor low voltage bank 2 sensor 1
            Are you still getting the same codes?
            I told you something is up with your o2 sensors. It's strange
            that they would go out this early, but you have those codes
            for a reason. And your scans show them being pretty much
            non-responsive so something is wrong. At WOT they are only
            show 35-50mV when they should be 880-920mV.
            Did you check the connections?
            Did you see if the wires got up against the exhaust manifold
            and shorted out?
              6 days ago
