Wiring up the LC-1 to AC Presure sensor ?? - FirebirdV6.com/CamaroV6.com Message Board
  • Wiring up the LC-1 to AC Presure sensor ??
    I read this on LS1.com after hearing it was possible. WIll this work on our cars? I have a 97.
    "I have an LC-1 because it was cheap and I was not afraid of a little wiring. It cost me 179.90 shipped. I used an old rear o2 sensor harness and was able to use my rear o2 sensor to get power, grounds and the signal to the PCM so I can log using Hp-tuners. Note I do not have the Pro interface (heck I still have the serial interface) so I had to use a signal going into my PCM to be able to log the AFR in HPTuners. With my setup I can use either the rear O2 signal (0-1v) or a wire to the AC Presure sensor (0-5v). I've been using the rear o2 because of the ease of install and uninstall. It takes me literally 5 mins. (including time to jack the car up) to remove or plug mine in."
    1997 silver Camaro RS<br />|T-Type Powered|<br /><a href=\"http://www.kwfbody.com\" target=\"_blank\">Looking for a local F-Body club in K/W, Ontario, Canada?</a>
    Re: Wiring up the LC-1 to AC Presure sensor ??
    yes it will work the same way with the v6 cars. Most people run it through the egr wiring if they removed their egr. Do you have just the standard hptuners and not the EIO upgraded interface?
    http://www.bowtiev6.com/
      Yes i have the standard and I dont' want to unplug my egr so this is much favourable..particularly since i ripped out my a/c stuff anyways :) Now I just have to find the a/c pressure sensor.
      Thanks.
        Oh, and which wire in the wideband mess of wires do i tap into??
