I need to find this to wire up my lc-1 wideband so i can monitor with hptuners. Anyone know where under the hood(if there) it can be found on a 97 Camaro?
Where is the ac pressure sensor switch?
Re: Where is the ac pressure sensor switch?
I found a wiring diagram for the a/c in my car.
Says there's a light blue/black wire going from the A/C Refridgerrant Pressure Sensor to a +5V source. Does that sound right?? There's also a red/black going to a/c sensor sig.
It says the pressure sensor is above the right front wheel well, attached to the refridgerant line. That sounds about right?1997 silver Camaro RS<br />|T-Type Powered|<br /><a href=\"http://www.kwfbody.com\" target=\"_blank\">Looking for a local F-Body club in K/W, Ontario, Canada?</a>
