PCM tune???? - FirebirdV6.com/CamaroV6.com Message Board
PCM tune????
  • PCM tune????
    OK so I'm figuring that one of the reason my maro runs rough is all my mods and my comp reprog...
    I've decided to go with PCMforless.com. Ive heard only good things. I know they need to know my mods cam size ect. But I was thinking of havingn them change my shift points, xing the VARS, and of course get rid of the governer because that should have never been on there in the first place.
    As for the shift points with should they be changed to for max performance both off the line and top speed?
    Re: PCM tune????
    Also how can I put a Z speedo in. what mods?? I know how the pyhsicaly install it but anything to the comp need to be done?
      Re: PCM tune????
      a Z speedo will cause your RPMs to be off on the speedo unless you buy the seperate plug in to change the RPMs, can't remember the name of the company though.
      what year car do you have?
      http://www.bowtiev6.com/
        Re: PCM tune????
        95 3.4 Obd I
          Re: PCM tune????
          for a modded engine they are not going to be able to help you then. They can do gears and fans, thats about it for the 3.4
          megasquirt is really the only option for the 3.4 guys
            Re: PCM tune????
            wheres the best place to get it and how hard is it?
              Re: PCM tune????
              also will i be able to program my cam into it and gear ratio's?
                Re: PCM tune????
                megasquirt is a stand alone system that would make everything pretty much tuneable, including for a cam. There are some turbo 3.4 guys going with the megasquirt for their buildups
                  Re: PCM tune????
                  Cool...I read the thread on it and know where to get it so next paycheck I'll be ordering it..
                  Thanks!
