broke a sensor - FirebirdV6.com/CamaroV6.com Message Board
broke a sensor
  • broke a sensor
    i barly tapped this sensor and it broke off, it's the one right above the oil filter.
    im guessing it's the oil pressure sensor, would i be correct?
    Re: broke a sensor
    send a pic, and i'll let you know. Is it inside the oil pan? I'll go look at mine after I get off work and let you know
    Car expresses who you are. If you have a ****ty car, you must be a ****ty person;)<br /><br /><a href=\"http://www.cardomain.com/ride/995979\" target=\"_blank\">http://www.cardomain.com/ride/995979</a>
      Re: broke a sensor
      i know which one you are talking about, not sure what it is sorry. V6motor its not on the pan, directly abouve the filter
      1997 Camaro LS1 RS
      1994 Camaro - Sold
      1999 Trans am Vert - Sold
      A Few Mods....
        Re: broke a sensor
        for the record, it was the oil pressure sensor
          Re: broke a sensor
          yep, its the ops, ty TOM
            Re: broke a sensor
            and if you take this sensor out, dont start the car cause oil will come out :)
              Re: broke a sensor
              lol thanks, it shoulda only costed you about $25 from the stealership. Sorry to hear you had to replace it :(
                Re: broke a sensor
                im just running without it right now, ill have to go and pick one up tomorrow.
                hopefully autozone carries it cause i think it will ocst like 50 bucks from the dealer
                  Re: broke a sensor
                  yea sadly, autozone will be close to the same price. If u have a local junkyard, go pick one up from them. They will last for a while reguardless of mileage usually
                    Re: broke a sensor
                    the one i got from autozone was only 24 bucks :)
