Make sure that all of your fuses are good, and also make sure that the contacts are clean on the port, and no wires are disconnected or damaged behind the port.
Also, your key needs to be in the 'on' position.
Representin' Team Red In The North
Red '96 Pontiac Firebird "Smokeshow" 3800, M5, Far From Stock!!
thats a check, car is in the on position and I checked the fuse over again. the cig lighter works so I know its not the fuse. I guess I gotta inspect the wires behind it and see whats up.
SLP CAI, RK Sport headers, P&Ped heads and intake, GT2 cam, Upgraded valvetrain, Z28 rear axle with 4.10s Tx Spd tune, Z06 rims, 2.5\" exhaust to flowmaster, 160* thermo, B&M ripper, upgraded ignition, rockford fosgate 12\" with sony xplode amp and HU.
