OBDII port update - FirebirdV6.com/CamaroV6.com Message Board
OBDII port update
  • OBDII port update
    so since the OBDII port wouldnt get any power when I hooked up HP Tuners, I took the kickplate off and inspected the wires aand whatnot. everything look fine so I started wiggling the wires around while HP Tuners was hooked up, the busy yellow light flickered. No matter what position I held the wires in the light would only flicker for a second and then go back off.
    what the F guys.......Do u think its the connection at the port itself? or somethin else?
    SLP CAI, RK Sport headers, P&Ped heads and intake, GT2 cam, Upgraded valvetrain, Z28 rear axle with 4.10s Tx Spd tune, Z06 rims, 2.5\" exhaust to flowmaster, 160* thermo, B&M ripper, upgraded ignition, rockford fosgate 12\" with sony xplode amp and HU.
    Re: OBDII port update
    Could be, with mine my cable was kinked, and I had to move it a certain way to get the connection. I just finally bought a new cable, going from pin style to a usb cable, works perfect now. Have you checked the connections up on your PCM, make sure their tighten down and move those wires a little, I had to do that before too. Just throwing out suggestions to ya.
      wire loose somewhere there
      http://www.bowtiev6.com/
        6 days ago
