my ses light came on today so i scaned it and came up with the code p0102 low voltage to mass. i cheked in the fuse box under the hood and found my engine sensor fuse was blown so i replaced scanned it again and cleared the code and everythign was fine, BUTT it came back on after 10 second, cheked under the fuse again and it was popped i disconected the maf and replaced the fuse and it still blew . from what ive read it could be one the the 3 o2 sensors. is there somethign special i should be lookign for like burnt wired or torn? any help should would apreciate it :)
MAF code and engine sensor fuse keeps on blowing
Re: MAF code and engine sensor fuse keeps on blowing
check your wiring first to the MAF sensor, look for any cuts or anything.
YGPM :D. Same thing was happening to me, and it turned out to be my O2 simulator was burnt up and grounding the whole system. It even blew 20A fuses :( (supposed to have a 5A fuse, IIRC)~97 3.8L V6 Camaro~
A few things
Only Member of Team Hooker?!?
ok so are the o2 sensors suppose move around cause when i was cheking them the one in the manifold looked ok then the one before the cat was able to move around like it was broken or something but i cant see around it because it has a piece of metal welded around it u guys think that might be my problem cause when i scan the car it only gives me the maf code but i unpluged the maf and it still burns my engine sensor fuse what do you guys think.
Originally posted by michael454rs@hotmail.comsay it is my o2 sensor that is messed up how do i take it out?~97 3.8L V6 Camaro~
A few things
And don't remove it when its still hot.. It can and probably will burn you along with stripping out the threading. At work.. we made fun of our supervisor for doing that to his own car. Try penetrating lube and patience. That seems to work the best with stuck bolts and 02 sensors. If that doesnt work out, a little heat wont hurt. Just not too much, ya know? And if you resort to heat, please do watch the fuel lines.
TEAM C6V6
Originally posted by Blizzard242And don't remove it when its still hot.. It can and probably will burn you along with stripping out the threading. At work.. we made fun of our supervisor for doing that to his own car. Try penetrating lube and patience. That seems to work the best with stuck bolts and 02 sensors. If that doesnt work out, a little heat wont hurt. Just not too much, ya know? And if you resort to heat, please do watch the fuel lines.
need help finding a balancer and a replacement balancer bolt. im at a lost after confusing myself researching.2 weeks ago
Hello every one, ozzy here ive been looking at this page for weeks now finally joined. So my question is why is it that every turbo build forum just ends...3 weeks ago
