I know you can unhook the battery and reset the pcm. i have also heard their are two fuses u can pull that do the same thing. anyone know what these are, and where their located? also do i just pull both of them and put them right back in, or do i need to leave the out for a bit. thanks for all the help...and i did search but couldnt find which fuses they were.
reset pcm
Re: reset pcm
look in your manual and it tells ya what fuse is the pcm or the back of the fuse panel
Re: reset pcm
Originally posted by lilchubbyI know you can unhook the battery and reset the pcm. i have also heard their are two fuses u can pull that do the same thing. anyone know what these are, and where their located? also do i just pull both of them and put them right back in, or do i need to leave the out for a bit. thanks for all the help...and i did search but couldnt find which fuses they were.Robert - owner www.FirebirdV6.com/CamaroV6.com
Raven
need help finding a balancer and a replacement balancer bolt. im at a lost after confusing myself researching.2 days ago
Hello every one, ozzy here ive been looking at this page for weeks now finally joined. So my question is why is it that every turbo build forum just ends...4 days ago
