reset pcm - FirebirdV6.com/CamaroV6.com Message Board
reset pcm
  • reset pcm
    I know you can unhook the battery and reset the pcm. i have also heard their are two fuses u can pull that do the same thing. anyone know what these are, and where their located? also do i just pull both of them and put them right back in, or do i need to leave the out for a bit. thanks for all the help...and i did search but couldnt find which fuses they were.
    Re: reset pcm
    ....why not just unhook the battery then?
      Re: reset pcm
      if your batter terminals are stripped like mine, then that is why =)
        Re: reset pcm
        thats the thing. i dissconnected both my terminals for over 2hrs last night. go to crank it up, and nothing reset. so thats why i wanted to try the fuses.
          Re: reset pcm
          hmmm interesting, well if anyone knows the right fuses i will need to do the same, the camaro is almost done.
            Re: reset pcm
            i read about it being the "2 pcm fuses" however i wasnt aware their were two.
              Re: reset pcm
              look in your manual and it tells ya what fuse is the pcm or the back of the fuse panel
              http://www.bowtiev6.com/
                Re: reset pcm
                You might check the engine bay fuse box as well.
                1996 Chevrolet Camaro
                1995 Buick Park Avenue Ultra
                --Appearance Moderator--
                  Re: reset pcm
                  yeah my fuse box panel says there is a fuse for the computer, but i wouldn't mess with it unless i had to.
                    Re: reset pcm
                    I've never had any luck trying to reset an OBDII PCM by pulling the fuse or unhooking the battery. It is easier and faster just to use a scanner.
                    Brian
                      Re: reset pcm
                      Let's start with, why are you trying to reset your PCM?
                      Raven
                        Re: reset pcm
                        1) reset codes
                        2)http://forum.camarov6.com/showthread.php?t=86248
