Autozone scanned it and said MAP/MAF. Car drove fine with a minor hiccup under part throttle. I just tried to drive it and was nearly killed when the "Reduced Engine Power" light came on. I was only a few blocks from home and I limped it back. I swapped the MAP and MAF out with two known good units I had in my garage. Light is still on and car won't rev past 2500. I did notice that when I hit the brakes, the engine would not rev at all in either park, neutral or drive. Engine revved to 2500 fine in all 3 selections as long as I didn't touch the brakes. The vacuume hose from the brake master cylinder to the intake manifold is attached. Where do I go from here?
P0102
Re: P0102
Update. Limped car to Vatozone. Following codes are now showing:
P1120
P1220
P1221
P1515
P1516
I'm kinda lost here now.<a href=\"http://www.fullthrottlev6.com\" target=\"_blank\">www.fullthrottlev6.com</a><br /><a href=\"http://www.chitownracing.com\" target=\"_blank\">www.chitownracing.com</a>
Re: P0102
Did they try to clear the codes for you?
Looks like you had something unpluged.
P1120 Throttle Position (TP) Sensor 1 Circuit
P1220 Throttle Position (TP) Sensor 2 Circuit
P1221 Throttle Position (TP) Sensor 1- 2 Correlation
P1515 Control Module Throttle Actuator Position Performance
P1516 Throttle Actuator Control (TAC) Module Throttle Actuator Position
Performance
BrianLast edited by bigbrian442; 01-11-2008, 09:16 PM.sigpic
Re: P0102
They did try, and I ended up renting a scan tool P1220 will not clear no matter what I do. Throttle body is plugged in and all connections are tight and dry.<a href=\"http://www.fullthrottlev6.com\" target=\"_blank\">www.fullthrottlev6.com</a><br /><a href=\"http://www.chitownracing.com\" target=\"_blank\">www.chitownracing.com</a>
Re: P0102
DTC P0102 Mass Air Flow (MAF) Sensor Circuit Low Frequency
Circuit Description
The mass air flow (MAF) sensor measures the amount of air which passes through it into the engine. The PCM uses the mass air flow information to monitor engine operating conditions for fuel delivery calculations. A large quantity of air entering the engine indicates an acceleration or high load situation, while a small quantity of air indicates deceleration or idle. The MAF sensor produces a frequency signal which can be monitored using a scan tool. The frequency will vary within a range of around 2000 Hertz at idle to about 10,000 Hertz at maximum engine load. DTC P0102 will be set if the signal frequency from the MAF sensor is lower than the possible range of a normally operating MAF sensor.
Conditions for Running the DTC
The engine is running.
Throttle angle is less than 1.5 percent.
Ignition voltage is more than 8.0 volts.
IAC is more than 5 counts.
Conditions for Setting the DTC
MAF signal frequency is less than 800 Hertz.
Above conditions are present for over 0.5 seconds.
Action Taken When the DTC Sets
The PCM will illuminate the malfunction indicator lamp (MIL) during the second consecutive trip in which the diagnostic test has been run and failed.
The PCM will store conditions which were present when the DTC set as Freeze Frame/Failure Records data.
Conditions for Clearing the MIL/DTC
The PCM will turn OFF the malfunction indicator lamp (MIL) during the third consecutive trip in which the diagnostic has run and passed.
The history DTC will clear after 40 consecutive warm-up cycles have occurred without a malfunction.
The DTC can be cleared by using a scan tool.
Diagnostic Aids
Inspect for the following:
Plugged intake air duct or filter element. A wide-open throttle acceleration from a stop should cause the mass air flow displayed on a scan tool to increase from about 4-6 gm/s at idle to 100 gm/s or more at the time of the 1-2 shift. If not, inspect for a restriction.
Many situations may lead to an intermittent condition. Perform each inspection or test as directed.
Important: : Remove any debris from the connector surfaces before servicing a component. Inspect the connector gaskets when diagnosing or replacing a component. Ensure that the gaskets are installed correctly. The gaskets prevent contaminate intrusion.
• Loose terminal connection
- Use a corresponding mating terminal to test for proper tension. Refer to Testing for Intermittent Conditions and Poor Connections , and to Connector Repairs in Wiring Systems for diagnosis and repair.
- Inspect the harness connectors for backed out terminals, improper mating, broken locks, improperly formed or damaged terminals, and faulty terminal to wire connection. Refer to Testing for Intermittent Conditions and Poor Connections , and to Connector Repairs in Wiring Systems for diagnosis and repair.
• Damaged harness--Inspect the wiring harness for damage. If the harness inspection does not reveal a problem, observe the display on the scan tool while moving connectors and wiring harnesses related to the sensor. A change in the scan tool display may indicate the location of the fault. Refer to Wiring Repairs in Wiring Systems for diagnosis and repair.
• Inspect the powertrain control module (PCM) and the engine grounds for clean and secure connections. Refer to Wiring Repairs in Wiring Systems for diagnosis and repair.
If the condition is determined to be intermittent, reviewing the Snapshot or Freeze Frame/Failure Records may be useful in determining when the DTC or condition was identified.
Test Description
Number(s) below refer to the Step number(s) on the Diagnostic Table:
This step verifies that the problem is present at idle.
A voltage reading of less than 4 or over 6 volts at the MAF sensor signal circuit indicates a malfunction in the wiring or a poor connection.
Verifies that ignition feed voltage and a good ground are available at the MAF sensor.
This vehicle is equipped with a PCM which utilizes an Electrically Erasable Programmable Read Only Memory (EEPROM). When the PCM is being replaced, the new PCM must be programmed.Last edited by David8399; 01-12-2008, 06:41 PM.96 camaro auto base model<br />slp cai<br />pacesetter headers<br />flowmaster catback<br />35th anniversary ss wheels<br />richmond 3.73<br />98+ ss spoiler<br />hypertech 160 degree thermostat<br />transgo shift kit
Re: P0102
DTC P1120 Throttle Position (TP) Sensor 1 Circuit
Circuit Description
The throttle position (TP) sensor is mounted on the throttle body/TAC assembly. The sensor is actually two individual throttle position sensors within one housing. Two separate signal, ground and reference circuits are used in order to connect the TP sensor assembly and the throttle actuator control (TAC) module. The TP sensor signal voltage increases as the throttle opens. The signal circuit for TP Sensor is pulled up to reference voltage.
DTCs P0606, P1517, P1518 are not set.
The ignition switch is in the crank or run position.
The ETC serial data is operational.
TP sensor 1 voltage is less than 0.34 volts or more than 4.4 volts as observed on the scan tool.
The PCM will illuminate the malfunction indicator lamp (MIL) during the first trip in which the diagnostic runs and fails.
If equipped with traction control, the PCM will command the EBTCM via the serial data circuit to turn OFF traction control and illuminate the TRACTION OFF lamp.
Diagnostic Aids
When the TAC module detects a problem within the ETC System the PCM receives a message across serial data and more than one ETC System related DTC may set. This is due to the many redundant tests run continuously on this system. Locating and repairing one individual problem may correct more than one DTC. Keep this in mind when reviewing captured DTC info.
If the condition is determined to be intermittent, reviewing the Snapshot or Freeze Frame/Failure Records may be useful in determining when the DTC or condition was identified.96 camaro auto base model<br />slp cai<br />pacesetter headers<br />flowmaster catback<br />35th anniversary ss wheels<br />richmond 3.73<br />98+ ss spoiler<br />hypertech 160 degree thermostat<br />transgo shift kit
Re: P0102
DTC P1220 Throttle Position (TP) Sensor 2 Circuit
Circuit Description
The ignition switch in the crank or run position.
The TP sensor 2 voltage is less than 0.25 volts or more than 4.49 volts.
Diagnostic Aids
Re: P0102
DTC P1221 Throttle Position (TP) Sensor 1- 2 Correlation
Circuit Description
The throttle position (TP) sensor is mounted on the throttle body/TAC assembly. The sensor is actually two individual throttle position sensors within one housing. Two separate signal, ground and reference circuits are used in order to connect the TP sensor assembly and the throttle actuator control (TAC) module. Each TP sensor signal voltage increases as the throttle opens. The signal circuit for TP sensors are pulled up to reference voltage.
TP sensor 1 and TP sensor 2 disagree by more than 0.17 volts.
Diagnostic Aids
Test Description
The numbers below refer to the step numbers on the diagnostic table.
When the TAC module detects a problem within the ETC System the PCM receives a message across serial data and more than one ETC System related DTC may set. This is due to the many redundant tests run continuously on this system. Locating and repairing one individual problem may correct more than one DTC. Keep this in mind when reviewing captured DTC info.96 camaro auto base model<br />slp cai<br />pacesetter headers<br />flowmaster catback<br />35th anniversary ss wheels<br />richmond 3.73<br />98+ ss spoiler<br />hypertech 160 degree thermostat<br />transgo shift kit
Re: P0102
DTC P1515 Control Module Throttle Actuator Position Performance
Circuit Description
The commanded throttle position, based on accelerator pedal position and possibly other limiting factors, is compared to the actual throttle position. The PCM monitors the Commanded and actual throttle position. This DTC sets if the PCM detects the problem.
No other ETC DTCs are set.
No PCM processor DTCs are present.
The ignition is in the crank or run position.
The ignition voltage is more than 8.5 volts with key ON engine OFF.
The ETC system is not in the battery saver mode.
The PCM detects that the commanded and actual throttle positions are not within a calibrated range of each other.
Diagnostic Aids
Important
Ensure that the starting and charging systems are operating properly. Low system voltage causes this DTC to set.
If you do not find any trouble, check for mechanical problems or binding that may be temperature related. Components may not move freely in extreme heat or cold due to the presence of contaminants or ice formation.
Test Description
If the TP indicated angle does not follow the movement of the throttle blade, and no TP sensor DTCs are set, there is a mechanical problem with the throttle shaft or the TP sensor. Replace the throttle body assembly. Re-install the air inlet duct after repairs are completed.
When the PCM detects a problem within the ETC System other DTCs may set due to the many redundant tests run continuously on this system. Locating and repairing one individual problem may correct more than one DTC. Keep this in mind when reviewing captured DTC info.96 camaro auto base model<br />slp cai<br />pacesetter headers<br />flowmaster catback<br />35th anniversary ss wheels<br />richmond 3.73<br />98+ ss spoiler<br />hypertech 160 degree thermostat<br />transgo shift kit
Re: P0102
DTC P1516 Throttle Actuator Control (TAC) Module Throttle Actuator Position Performance
Circuit Description
The commanded throttle position, based on accelerator pedal position and possibly other limiting factors, is compared to the actual throttle position. The TP values should be within a calibrated range of each other. The TAC module monitors the Commanded and actual throttle position. This DTC sets if the TAC module detects the problem and send the message to the PCM across serial data.
DTC P1518 is not present.
The TAC module detects that the commanded and actual throttle positions are not within a calibrated range of each other or the TAC module cannot determine throttle position or both TP sensors are invalid.
Diagnostic Aids
Important
Test Description
Re: P0102
that should be all of them96 camaro auto base model<br />slp cai<br />pacesetter headers<br />flowmaster catback<br />35th anniversary ss wheels<br />richmond 3.73<br />98+ ss spoiler<br />hypertech 160 degree thermostat<br />transgo shift kit
